Auto to manual tranny swap, possible?
Old Mar 26, 2007 | 09:51 PM
okefanoke's Avatar
I've got a '88 Z28, 5.7 TPI, pretty much all stock. Is it possible to swap the auto tranny with a 6 speed? If so, what would be involved?
Old Mar 27, 2007 | 12:51 AM
Rage's Avatar
Certainly. It's not to hard either. You will need a T56, of course, a Clutch Master Cylinder, Slave cylinder, and you can either take a pedal assembly out of a 4th Generation f-body,(recommended) or do some fabrication to your existing pedal assembly and add the clutch. You'll need a new crossmember(Spohn makes them) and other things Im sure Im forgetting.
You'll have to cut a hole in the floor where the shifter will come through, but other than that, it's pretty straight forward. Also, you have mechanical guages, any 6 speed you get will be configured for an electrical gauge. My fix is to buy new guages, but there are other alternatives you can look into. I believe there is a company who makes a tailshaft for these kind of swaps. Several people have done it here, it isnt too hard at all.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
nballisru
Dec 14, 2014 05:01 PM
Snoman73
Nov 17, 2014 07:22 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
