anyone wanna touch this?
Old Mar 22, 2004 | 06:42 PM
greezemonkey's Avatar
Anyone wanna touch this......
I`m starting to get use to the price of the m6 and Want to know if anyone thinks it can be put behind a big block for a reasonable amount of coin? I`m looking to find out if the lt1 6 er can fit the big block, not weather it`s smart or not. The big blocks only came with a 14 inch flywheel and the 6 speed only uses a 12 and 3/4 right? So what do I do
Old Mar 22, 2004 | 09:33 PM
AutoRoc's Avatar
Call someone who makes a living working with T-56 transmissions. Any one of the big names. D&D And Liberty come to mind. They'll know. An adapter plate of some sort maybe. A Viper spec T-56 would be sweet also which I think D&D sells for around 2200-2500. Goodluck!
Old Mar 23, 2004 | 07:50 PM
TheGreatJ's Avatar
The LT1 trans will hold up to the big-block (assuming it's not some kind of 800hp beast) but the flywheel/clutch is definitely going to be an issue.
Maybe you could get a machine shop to drill/balance an LT1 flywheel to fit the big-block? Just an idea.....
Old Mar 23, 2004 | 10:34 PM
Zepher's Avatar
I don't think it should be a problem getting them to work together. A buddy of mine is running a T5 behind a 502 big block. Only things saving the tranny are the tires and the clutch.
Old Mar 24, 2004 | 02:14 PM
Z28SORR's Avatar
It's a bolt in, if you buy the one designed for the "old"/standard bellhousing.
Old Mar 24, 2004 | 03:50 PM
I`m sure the bellhousing`s gonna work, it weather or not the the bellhousing will accept the 14 inch flywheel, because far as I know the t-56 only came with the 12 3/4 in the chevy version...there is no 454 flywheel in 12 3/4 is there?
Old Mar 25, 2004 | 01:26 PM
Z28SORR's Avatar
http://www.sallee-chevrolet.com/BorgWarner/bwt56.html
Read this page. This trans. use the old/standard bell housing that fit BB's and large flywheels.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 11, 2015 06:16 PM
Latronaxe
Jul 17, 2015 11:55 AM
surreybrad
Jul 5, 2015 10:36 PM
