anyone know any sure ways of telling if an ecm or memcal is bad?
Old Jul 25, 2004 | 08:11 AM
xeroxed's Avatar
i just got an 87 trans am with a 305 tpi engine. it wasnt running right itd skip and sound out of time and was burning really rich. i noticed a bunch of vacume lines not hooked up so i hooked them up as best as i could without a vacume diagram and that got rid of the rich problem. but it still has a skip and a pop threw the exaust after its revved as the engine revs are going down. so i checked the codes and it popped up the normal code 12 and then code 41 and that was it. which i guess means it needs a new memcal or ecm. im just trying to figure out if theres a way i can check these without needing to use a friends stuff because i dont know anyone with a tpi car except someone that has a custom memcal he burnt and its an 86 which im not sure if there the same.
Old Jul 25, 2004 | 02:51 PM
Zepher's Avatar
Re: anyone know any sure ways of telling if an ecm or memcal is bad?
If the memcal is bad it will run in limp home mode and run extremely rich.
I ran my car for 6 weeks with a bad prom which I didn't know was bad.
here is vid of it,
http://www.transamws6.com/video/ZepherWS6.mpg
Old Jul 25, 2004 | 04:52 PM
xeroxed's Avatar
was that video taken when the prom was shot?
Old Jul 25, 2004 | 05:15 PM
Zepher's Avatar
Ya, the prom wasn't working at all in that video. We shot that video 2 days after the TPI swap was done. My programmer was burning bum chips but it looked like it was burning them correctly.
This is the carb setup I had originally,
Here is the TPI setup I installed,
meissen
Jun 1, 2015 07:59 AM
warmeck
Jan 20, 2015 09:20 PM
4586
Dec 31, 2014 02:21 PM
4586
Dec 6, 2014 05:20 PM
