anyone have 1992 camaro rs specs......
Old Aug 20, 2002 | 07:35 PM
*SoRRy OfFiCeR*'s Avatar
Thumbs up anyone have 1992 camaro rs specs......
i am looking to learn a bit more about the 1991-1992 camaro z28's and rs's......all i know is that they have 305's....
ps-does anyone know there suspension setup?
Old Aug 20, 2002 | 10:19 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Post
The Z28 can have a 305 TPI V8 rated at either 205 HP or 230 HP depending on options, or the 350 TPI V8 rated at 245 HP. The RS will have a V6 rated at 140 HP or so, or the TBI V8 rated at 170 HP. The Z28 will have a better suspension setup, bigger sway bars, stiffer springs and shocks, etc.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
Old Aug 21, 2002 | 01:51 PM
Brett 91 RS LT1's Avatar
Post
Only interior difference will be the gauge cluster since the RS has a 110 and the Z28s should have the 145 mph speedo.
Don't forget, all RS's have an open rear while the Z28s have posi. I have been told, but have never seen proof, that the 700R4s differ between the two with the Z getting stronger internals.
'91 RS Camaro - red/black, NA 450hp LT1 355. Set to run 12psi+
'00 C5 Coupe - black/black coupe, my beautiful lawn ornament.
Chewbacca is NOT dead!
bs.cz28.com
350.streetracing.org/lt1d.html
Old Aug 21, 2002 | 01:52 PM
Post
And just as an extra.... Don't forget that in 91 and 92 there were some RS's that came with the B4C option code. This meant that they came with a TPI engine in 305 or 350 and the full 1LE performance package PLUS Air Conditioning which was a delted option on all Z28 1LE cars. Kind of cool if you can find one, but they were almost exclusively police cars and have high miles now.
Old Aug 21, 2002 | 04:57 PM
Question
what kind of v8 has only 170 hp? weak!!!
also......what is tbi.throttle body injection..but what is that in comparison to tpi or mpi?
Old Aug 22, 2002 | 12:16 AM
Kevin91Z's Avatar
Post
Dont confuse the guy with the 1LE or B4C stuff. Its very rare you will run across one.
I dont think the Z28's had a better transmission, but I could be wrong.
The Z28's without the G92 option will have the 110 MPH speedo too. The G92 option is dual catlytic converters and a better rear end with disc brakes.
TBI has two injectors on top of the throttle body, while TPI has 8 injectors, one at each port where the intake manifold meets the heads. TPI is definitely better but costs more and is a lot more complex.
Check out the Tech Database and the FAQ at http://www.thirdgen.org/ to answer more of your thirdgen questions.
Old Aug 22, 2002 | 01:22 AM
slimdawson's Avatar
Post
The RS could also be had with the same size diameter sway bars as the Z28s. You had to get the optional 16" wheels.
You are right about what kind of v8 comes with 170 hp. Some came with less but it is nice to have an RS with more than 170. Most people look at my Camaro and underestimate it. I of course don't tell them any different so when they lose, they wonder why. Not that it is all that fast, but they think they can play with me.
Pix of my rides!
Finally have some pictures of Y2k Vette wheels, motor, etc.
*1991 Camaro RS !LO3
8.65@84.3mph NA
*1988 Mustang 5.0 7.92@87 NA- For Sale
*1988 Mustang GT 'vert
9.56@73-bone stock
*1986 Kawasaki Ninja 1000R 7.30@100mph
*1987 Honda CRX Si 16.5@85mph-stock
100% American!
Old Aug 22, 2002 | 12:23 PM
Thumbs up
when did the g92 option start being offered..and besides a disc brake rear what else was offered? 3.23's...2.73's?
Old Aug 22, 2002 | 01:14 PM
Bristol's Avatar
Post
I know that the 305 1LE cars got 3.42s and my 350 1LE has 3.23s.
Old Aug 22, 2002 | 04:22 PM
Chuck!'s Avatar
Post
With the 16" rims (F40 RPO code) the RS had the same sway bars as the stock Z28s, but the Z28s could upgrade to the mammoth 36/24 F41 suspenions, bastards
Chuck Kulchar
1991 Camaro RS LO3 A4
Now with 100% more Vortec heads!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
92ragtop
Dec 27, 2014 01:56 PM
ChrisFrez
Dec 21, 2014 09:47 PM
