Anyone ever put a 91 dash in an 85?
Old Mar 9, 2003 | 10:24 PM
Polo-94Z28's Avatar
Cool Anyone ever put a 91 dash in an 85?
Topic is just like it states. Has anyone taken the instrument cluster from a 91 camaro and placed it into an 85 camaro?
Also, are the steering wheels switchable? 91 into 85? (i know the 91 has an airbag as well)
Laterz
Old Mar 9, 2003 | 11:16 PM
Aaron91RS's Avatar
You can switch the steering wheel.
The guage cluster will not drop in. You'd have to replace the whole dash unless you cut your current one. Also your 91 speedo is electronic while the 85 probably has a cable.
Old Mar 10, 2003 | 01:19 AM
Polo-94Z28's Avatar
Cool thanks. I will be using an electronic speedo with the 91 dash. I do have the entire dash from the 91, just was hoping the cluster might somewhat pop in. Oh well, thanks for your input!
Laterz
Old Mar 10, 2003 | 01:42 PM
85LT1Z28MEX's Avatar
__________________
yep... you can swap the hole dash, but, your speedo will not work---
Old Mar 10, 2003 | 05:30 PM
Polo-94Z28's Avatar
Hmm... well I am using the trans from the 91 which has the electronic speedo on it. Will it not work with that still? Or is the ECM responsible for the speedo ?
Thanks again
-Zach
:edit: I might as well say I have both cars, the 91 and the 85. 85 had the 2.8 MPFI engine with auto and the 91 was an RS with auto as well. Not using the engine from either. The 91 is a parts car for the 85.
Old Mar 10, 2003 | 07:27 PM
TheGreatJ's Avatar
The VSS signal goes to the ECM which drives the speedo. So no, the speedo still will not work.
Old Mar 10, 2003 | 08:52 PM
Polo-94Z28's Avatar
Hmm... I see what you mean.
Do you perchance know what the voltage output from the ECM is as well as what in input from the VSS is?
The VSS puts out ac and the speedo uses dc. But what are the ranges for the voltages?
chuyz28
Parts Wanted
Jan 7, 2015 05:25 PM
nikko
Dec 2, 2014 03:43 PM
Snoman73
Nov 17, 2014 07:22 PM
BigED
Jul 26, 2002 09:22 AM
Timberwolf
Jul 20, 2002 08:45 AM
