ANYONE with a 305 tpi !!
Old Aug 5, 2003 | 12:06 PM
shwine617's Avatar
If you have a 305 TPI and if you still have stock fuel injectors....what color are they, and if you know the numbers on them, that would help too, thanks!!
Old Aug 5, 2003 | 02:15 PM
10sallday85Z28's Avatar
mine are black no clue about the numbers but ill check and get back to you later
Old Aug 5, 2003 | 03:48 PM
87DJP2001's Avatar
Here is the GM a/c delco Part Number for the 305 19# FI 17111960 and the color is black. Again GM did not color code the FI's. Note! for 87-88
Old Aug 5, 2003 | 04:48 PM
shwine617's Avatar
mine are green, I don't know what size they are, also do i have to take them off to get the number? where is the number located?
thanks
Old Aug 7, 2003 | 12:11 PM
MY91Y84's Avatar
gm changed there injectors for the SD cars...
early ones are black and the later "multec" injectors were like a aqua color...
Old Aug 7, 2003 | 02:33 PM
shwine617's Avatar
What is a "SD" car ??
mine are aqua colred, what size is that?
Old Aug 7, 2003 | 06:59 PM
Rice Killer87's Avatar
SD means Speed Density. it changed in 1990 i believe from MAF (Mass Air Flow) to SD.
Old Aug 7, 2003 | 10:09 PM
MY91Y84's Avatar
you have 22#'ers
the 305's had 19#er's
Old Aug 8, 2003 | 08:09 PM
shwine617's Avatar
yes, I know that 305's have 19lb and 350's have 22 lbs, but my car was originally a 305 that was swapped with a 350 block, but still has the original TPI, So I am not sure if the injectors were changed or not? I am trying to get the part numbers ASAP.
G-BODYT56
Jan 14, 2022 11:14 PM
Tarizza
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
