Any way to test MAF?
Old Feb 26, 2004 | 05:41 PM
Black6SpdTA's Avatar
I know MAF's are $300+. Is there anyway to test the one I've got? It all looks 100%.
If it's not good, I'd like to go ahead and get the parts ready for a SD setup. If it's good, I'll stick MAF. You know, just don't want to have her ready to fire up and bad MAF.
Old Feb 26, 2004 | 08:39 PM
97WS6SCharged's Avatar
Usually you test it by unplugging it while the car is idling. If the idle starts acting funny then the MAF is generally ok. If not, then it's probably bad. I'm not sure how you would test it while it's off the car though.
Old Feb 26, 2004 | 08:42 PM
Haha, so go find a MAF car, replace it with mine. Then follow your procedure.
Anyone else know a way?
Old Feb 27, 2004 | 12:14 AM
90rocz's Avatar
There's a "tap" test, just tap it with a screwdriver handle while idling, if the engine stumbles, the MAF is bad...Also, the MAF has a fuse, usually on a fenderwell, a red wire and a yellow wire going to a dead end fuse...
What's the original problem??
Old Feb 27, 2004 | 07:18 AM
There isn't an original problem. It, as well as all the electronics/engine are out of the car. I'm building the L98 up
I'd like to changeover to SD but if I can stick MAF, I will. Simply because of $. So if the MAF is bad, instead of laying down $300 for a new one, I'll just round up SD components for ~$100.
Old Feb 27, 2004 | 10:14 AM
aklim's Avatar
To be absolutely sure you would need a scanner and hook it up to another car. That way you can see readings on both MAF units and see if you have about the same readings.
Old Feb 27, 2004 | 08:44 PM
I'd go with a SD setup if I had the choice. A little bit harder to tune, but you don't have a sensor adding more restriction to the incoming air. Plus, you don't have to worry about where you're going to mount the MAF so you can make your cold air intake into just about anything you want.
Old Feb 28, 2004 | 12:21 PM
highboost's Avatar
what year maf do you have i have a brand new gm spare in boxx $200
KYWes
Jun 14, 2022 06:52 AM
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
