Am I in too deep?
Old Apr 30, 2005 | 11:50 PM
  #16
iansane's Avatar
Re: Am I in too deep?
Not hard at all. When I put the t56 in that part of it only took a couple minutes with a rotozip. Just make sure your cutting in the right spot.
Old May 1, 2005 | 09:00 PM
  #17
85_305's Avatar
^Where is the right spot, lol?
Old May 1, 2005 | 09:05 PM
  #18
iansane's Avatar
It's easy to find once the tranny is in the car (without the shift mechanism that is).
It's been over a year since I did the swap but the backside of the hole was right before the tranny tunnel forms a U-shape. Hard to explain now that I try but there's a flatter section of the tranny tunnel and the hole I cut was at the back of this.
Old May 1, 2005 | 09:26 PM
  #19
85_305's Avatar
All I would be doing is widening out the hole, right?
Old May 1, 2005 | 09:58 PM
  #20
iansane's Avatar
Well you don't technically widen it. If you car originally car was originally a 5-speed you just extend the hole back a inch or so, so the shifter doesn't hit the tunnel when you're in 2nd, 4th, and 6th.
Old May 1, 2005 | 10:49 PM
  #21
doug791's Avatar
i believe its 2" and the hole is the same between the 700's and t-5's
Old May 1, 2005 | 11:31 PM
  #22
iansane's Avatar
Well if you have a 5speed car you just extend the hole. If it was an auto car then you have to cut the entire hole because they wasn't one to begin with.
Old May 2, 2005 | 12:12 AM
  #23
doug791's Avatar
autos still have a shifter that need to go just as far front to back, i believe the auto shifter hole is the exact same as the t-5
Old May 2, 2005 | 12:41 AM
  #24
iansane's Avatar
The autos only have one circular hole about 1" in diameter near the front of that flat spot (for the shifter cable). Nowhere near big enough for even a t5 shifter. The auto shifter is just a bracket with a cable attached, it doesn't go through the floor.
Old May 2, 2005 | 02:37 PM
  #25
85_305's Avatar
Ok, thank you
Old May 2, 2005 | 10:38 PM
  #26
iansane's Avatar
No prob. Any more questions post or PM me. I always like helping another guy get a manual trans going.
Old May 3, 2005 | 01:47 PM
  #27
85_305's Avatar
^Ok, will do
BTW.. I already have the T5, just looking for a T56
2QUIK6
Sep 17, 2016 02:31 PM
PopoFormula
Oct 12, 2015 04:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
mlopezart
Sep 8, 2015 12:15 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
