Alternator won't charge
Old Jul 10, 2003 | 05:31 PM
speedfreak85's Avatar
My car is an 88 camaro, with a carbureted 350 and a th-350 trans in it. I have the fuel pump hooked to a switch, so that I could remove the computer and ECU harness. So I removed everything and now my alternator doesn't work. I did find that the white wire coming from the alternator plug went to the computer, but when I unplugged the computer it worked fine. Why doesn't the alternator charge now? What does that white wire do? Is there anyway to hook it up so it does work? Any help is appreciated.
Old Jul 10, 2003 | 06:21 PM
irocz383's Avatar
I'm not 100% sure but I think that might be the load wire. Basically it tells the alternator how much charge to give the batterie. Yuo probaly could get away with just putting power directly to it but I'm not sure if that will damage the batterie at all.
I would check your vehicles wiring diagram first.
Old Jul 10, 2003 | 06:30 PM
Ok, I'll try that out. And don't worry, you won't be held accountable
Devinfoote87
Feb 12, 2016 03:21 PM
MikeWhitener
Aug 2, 2015 06:17 PM
Thirim
Jul 30, 2015 01:29 PM
Jlo
Jul 29, 2015 03:52 PM
Boss002
Jul 24, 2015 10:47 AM
