Alternator Help!!
Old May 11, 2003 | 04:35 PM
gillbot's Avatar
Alternator Help!!
On the back of my Bro's 87 Camaro LT alternator it has a post labeled "BAT" and it was hooked to the negative battery terminal. Isn't this for charging? Shouldn't it be connected to the positive terminal? It also has a splice off of it heading somewhere under the car but i'm not sure where it goes.
We took this off and the car started just fine w/o it three times in a row (It wouldn't before w/o a jump) but I'm not sure if it's because I removed that wire or just because we let it sit for a bit.
With the wire off and the car running, the alternator wasn't putting out any voltage by reading from the ground to the "BAT" terminal. I'm guessing if it was hooked backwards, the alternator is fried.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
