Air Line to the Cat
You can eliminate it if you take the rest of the A.I.R. system out too. You can't realy remove it from the cat unless you have a welder to close the hole up with (talk about an exhaust leak!!).....what you can do is cut it off a couple inches from the cat, fill the end with JB Weld, and crimp it down with some really big pliers. Once the JB sets up it'll be sealed real good.
Re: Air Line to the Cat
Originally posted by SilentBob
Does anyone see any issue in eliminating the air line that runs down to the cat? This is only used to help light it off initially, correct?
SB
SB
95chwagon
Jan 13, 2015 09:19 PM
Dec 1, 2014 08:08 AM
Jul 4, 2005 05:00 PM
