ACC fuse keeps blowing !!!!
Old Feb 27, 2003 | 09:10 PM
NOMAD's Avatar
Angry ACC fuse keeps blowing !!!!
Driving the 88 2.8 one night and I start to hear clicking like a relay kicking under the dash, then i lose stereo and courtesy lights.
I can't even put a fuse in it. As soon as it makes contact, it blows. I've pulled the stereo, and no problems there.
Does anyone have any ideas ? It didn't blow the fuse until this clicking started
-Shannon
Old Feb 27, 2003 | 10:38 PM
Pod99966's Avatar
Here is a great page I found a link to, on Thirdgen.org
http://92b4crs.tripod.com/86wiring/86wiringindex.html
about halfway down you'll see Fuse Box Details and under that ACC Fuse
It shows just about everything that draws from the ACC fuse, one of them should be your problem.
The radio only draws a small bit from that fuse for clock and station memory so I doubt that it's the radio.
Old Feb 28, 2003 | 09:20 PM
85SCwgfx's Avatar
I had this same problem on my car. When I would turn on the lights the fuse would blow, check for any frayed wires. I found a few that were frayed and shorting out. Also check your horn,blinker relays, and the buzzer thing. They are located just behind the aldl, they are on a little black square that swings down when you release the tabs that hold it up.
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
