Air cleaner extras
Old Feb 24, 2004 | 10:36 PM
transxtreme's Avatar
Air cleaner extras
Alright, i changed my air cleaner today. All the plugs and junk built into the assembly of the air cleaner? What are they? I belive there are like 3 and an aditional air cleaner.
Old Feb 24, 2004 | 11:32 PM
aklim's Avatar
What engine?
Old Feb 25, 2004 | 06:51 PM
Woops, 305 TBI.
Old Feb 25, 2004 | 11:42 PM
PyRo9862's Avatar
The other air cleaner is for the PCV right?
Your IAC valve is the little dealie towrds the back, senses the temperature of the incomming air.
And taht other thing that says AC on it I havn't figured out yet.
Old Feb 26, 2004 | 05:34 PM
TheGreatJ's Avatar
The sensor is an IAT not an IAC. Inlet Air Temperature...tells the ECM how hot the incoming air charge is. You need it hooked up at the very least, preferably inside the new air cleaner. The vacuum lines are for the Thermac (big round thing on the old air cleaner snorkel) and should be eliminated and the port capped. The small foam filter inside the air cleaner is the PCV filter. You can just plug a breather into the hole in the valve cover that it goes to, or get one of those fancy K&N breather-filters.
Old Feb 27, 2004 | 12:28 AM
So i have to have that IAT plugged in? How will the car run if i just leave it below the air cleaner. The air cleaner should be getting the same temp air right since its right over it.
Old Feb 27, 2004 | 12:57 PM
TheGreatJ's Avatar
It should be ok if it's not actually touching the intake manifold. That will throw off the reading.
Fatdog2
Feb 13, 2015 08:19 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
stanghunter211
Aug 29, 2002 03:04 AM
