Air cleaner extras
The sensor is an IAT not an IAC. Inlet Air Temperature...tells the ECM how hot the incoming air charge is. You need it hooked up at the very least, preferably inside the new air cleaner. The vacuum lines are for the Thermac (big round thing on the old air cleaner snorkel) and should be eliminated and the port capped. The small foam filter inside the air cleaner is the PCV filter. You can just plug a breather into the hole in the valve cover that it goes to, or get one of those fancy K&N breather-filters.
95chwagon
Jan 13, 2015 09:19 PM
