Air cleaner
Old Jan 25, 2003 | 03:24 PM
cowlcamaro's Avatar
Question Air cleaner
If I whould put a open air filter on my 91 RS TBI 305 instead of the stock one whould I have to worry about not using the hoses and wires hooked up to the old air filter
Old Jan 25, 2003 | 07:35 PM
stanghunter211's Avatar
All you would need to do is prolly plug that vacuum line and put a breather on the Crankcase filter tube(inplace of the tube). Should work well.
Will
Old Jan 25, 2003 | 09:06 PM
Dragons91RS's Avatar
and dont forget to remove the temp sensor from the bottom of the stock air cleaner and keep it pluged up(your ses light will come on if you leave it unpluged). just move it off to the side out of the way. but keep it away from the exhaust.
Old Jan 25, 2003 | 09:16 PM
Ya, my 86 doesnt have the temp sensor, forgot about that one!
Will
Old Jan 26, 2003 | 10:56 AM
CODY BEHNKE's Avatar
Block the vacume line at the TB, drill a hole in the new air cleaner bottom and install the IAT module there.
Old Feb 16, 2003 | 07:06 PM
XThree's Avatar
Great? this is exactly my problem. I just Added a Goodmark Cowl Induction hood, and added a high flow aftermarket air cleaner but did not have anywhere to put the IAT sensor so I didn't plug it back in, and my Check Enging Light started coming on.
Anyone know of after market 14 inch Air cleaner that has a hole for this already? or should I just buy the appropriate size drill bit to make my own hole for the sensor?
Old Feb 16, 2003 | 07:42 PM
Just plug the IAT sensor back up and tie it off to the side some where with a zip tie(not near the exhaust manafold) or tuck it under the air cleaner near the dis and coil.
Old Feb 16, 2003 | 08:58 PM
XThree's Avatar
wouldn't leaving it out of the air cleaner cause some things to change in the ECM? like timing adjustments or something? ive been reading on these boards about people movind there IAT sensor around. and getting differnet results..
Old Feb 17, 2003 | 07:29 PM
TheGreatJ's Avatar
The IAT is just what it's called....it senses the temperature of the air at the inlet. People move them around on TPI setups to help offset the heat saturation that can be caused by the aluminum intake, with a TBI system that isn't a problem. The air near your air cleaner is the same temperature as the air being pulled into the air cleaner, so as long as it isn't next to the exhaust (lots of heat there) it will work just fine. The extra heat from the engine bay will just make your car think you're in Pheonix.
Fatdog2
Feb 13, 2015 08:19 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
stanghunter211
Aug 29, 2002 03:04 AM
