Accel 24# injectors, are they rated 24# according to GM or Ford?
Old Apr 22, 2003 | 10:12 PM
RedIrocZ-28's Avatar
I need to know pretty quick here, I am about to order them from Summit and need to know if they are rated at 38psi like ford or 45(?) like GM?
Old Apr 23, 2003 | 04:41 AM
Chris Ja's Avatar
Eternal Member
Smile
Brad I was told by Ed Wright not to use the Accel injectors. I didn't ask why. You should email him and see what he says.
I use the SVO 24lb injectors and never had a problem. I would think Detroit Speedworks would have some laying around. I would give Greg or Phil a call.
Old Apr 23, 2003 | 07:25 AM
Jim85IROC's Avatar
There seems to be some speculation about the size of the SVO injectors, but I was told they were rated at the lower fuel pressure, so they translate into around a 26lb/hr injector with GM fuel pressure. I decided to split the difference and programmed my PROM for a 25lb injector, and my block learn numbers look great.
Old Apr 23, 2003 | 10:33 AM
Chris, please elaborate!
Whats the cost for the 24# SVO's?\
Got a number that I can call?
Old Apr 23, 2003 | 10:35 AM
Jim, you're right. They figure out to 26.12# injectors when rated at GM fuel pressure.
KYWes
Jun 14, 2022 06:52 AM
mrwz28
Jul 8, 2015 09:11 PM
MichiganSkip
Aug 31, 2002 08:52 PM
MichiganSkip
Aug 16, 2002 08:17 PM
MichiganSkip
Aug 16, 2002 08:09 PM
