? about timing & timing tab
Old Feb 16, 2005 | 11:38 PM
splinter_cell's Avatar
Does anybody have a picture of the timing tab that shows the #'s? The #'s on my dads 86 Iroc cant be read. Also on the underhood sticker it says the timing should be 6 degrees DR. What does the "DR" stand for?
Old Feb 17, 2005 | 01:08 AM
90rocz's Avatar
Re: ? about timing & timing tab
It should read 6 degrees BTDC or "Before Top Dead Center".("advanced")
And the "0" on the tab is the largest valley notch, and each point going counterclockwise is in 4 degree increments. 0, 4, 8, 12 "advanced"...the valleys between the peaks are, 2, 6, 10.
On the other side (clockwise from "0") is 4, 8 degrees "retarded"
And you must disconnect the single tan wire with black stripe timing connector on the main harness above the heater-blower, when setting timing.
Old Feb 17, 2005 | 05:27 PM
Marc 85Z28's Avatar
If the car is fuel injected. Carbed cars you must disconnect the large 4 pin connector leading to the distributor that's usually wedged between the block and firewall.
Old Feb 17, 2005 | 09:12 PM
rsn932's Avatar
the "DR" means when the transmission is in drive
Old Feb 17, 2005 | 09:22 PM
90rocz's Avatar
This is telling you to have the vehicle in "drive" when adjusting the idle speed, not the timing.
Feffman
Oct 9, 2015 05:42 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Black Sunshine/ 00SS
Jul 17, 2002 08:41 PM
Ude-lose
71
Jul 17, 2002 04:52 PM
