97 lt1 swap into thirdgen using 700r4
Old Nov 13, 2007 | 09:01 PM
kv91's Avatar
hi every one, i am looking at puting a lt1 from a 97 trans am into an 83 camaro, i plan on using a 700r4 from a 91 camaro that i also have, my over all goal is to take everything i like from the 91 camaro and put it on the 83 to avoid the emissions test we have here canada i also wanted t-tops wich is another reason for the car switch, but the biggest concern is the lt1 swap, if any one has done one similar to this your help would be greatly appreciated
Old Nov 14, 2007 | 03:46 AM
jay_rich's Avatar
ADD me up on MSN if u have it.... jamesrichard727@hotmail.com
I see we both live in windsor and I have a 87 with a 95 LT1 Swap ...
DAMN I just relized HI Kyle. I knew 1997 LT1 and 91 camaro rang a bell.
You can use my car as a diagram when u wanna do the swap
Jay
Old Nov 14, 2007 | 06:27 AM
1987IROC350's Avatar
I see your all set up but, have you considered an LS1 swap?
I've even seen an intake for the LS1 motor that allows you to go carbureted for a simple swap vs. using the LS1 fuel injection.
This kit also includes a special throttle and transmission bracket that works with 700R-4
Here is the link to the parts.
http://www.jegs.com/webapp/wcs/store...55239_-1_11939
Noer
Feb 28, 2015 11:29 AM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
