92 Z28
Old Jun 18, 2008 | 05:53 PM
roby's Avatar
92 Z28
I Have A 92 Z28 With L98 Engine. I Installed Accel 22 Pounds Injectors. What Else Can I Install That Is Not Too Expensive But Gives Extra Power.
Old Jun 18, 2008 | 08:15 PM
lordmetalz28's Avatar
headers, full exhaust,
Old Jun 18, 2008 | 08:39 PM
imadude1134's Avatar
You also should upgrade the ignition system, K&N air filters, SLP/Accell/S&M runners and base, port the plennum
These cost a little bit of money, but they are the big gains: new heads, a cam...
Old Jun 18, 2008 | 09:28 PM
rik89gta's Avatar
Before You think about adding mods.... Make sure Your car is in proper tune. How long has it been since Your spark plug, wires, cap and rotor, fuel filter, and O2 sensor have been changed? Once those are all up to par... You can do simple free mods like bypassing the throttle body coolant hose and advacing Your timing. If Your handy with a die grinder, You can port Your plenum which is located behind the throttle body. Look at all the small things that will all add up and make the difference between a slouch and a good runner.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
