91 Z28 Ignition Module
Old May 1, 2007 | 10:17 PM
DOUGDREZ28's Avatar
I Have A 1991 Z28 It Has Been Running Rough Ive Changed Plugs And Wires Also New Gas As It Has Been Sitting For A Couple Of Months. It Seemd Like When Engine Got Warm It Would Start Running Rough. I Changed The Ignition Module And Now Vehicle Will Not Start. The 2 Connecting Wires Are Green And Yellow.does Anyone Know Wich One Is Positive And Wich Is Negative. Im Not Sure If I Had Crossed Wires As Now It Will Not Start After I Change Module
Old May 1, 2007 | 10:26 PM
DOUGDREZ28's Avatar
test
Old May 1, 2007 | 11:13 PM
LesPaulGoth's Avatar
Not sure which one is which, try swapping them maybe?
Old May 2, 2007 | 12:33 AM
antoine's Avatar
maybe he is talking about the pickup coil wires.
Old May 2, 2007 | 09:29 AM
No, he's speaking of the ignition module found inside the cap of the distributor.
Do you have the old one still? Put it back in and see what happens.
Old May 2, 2007 | 02:14 PM
jaykar's Avatar
Module
Keep in mind that an ignition module either works
or doesn't work, there's no in between.
Later
Old May 2, 2007 | 09:16 PM
Exactly which is why I said to try the old one again, maybe the new one is a dud or he fried it.
Old Jun 29, 2007 | 07:50 PM
TEG99SS's Avatar
anybody else having this problem?
I just did a search, tons of stuff with "running rough" but has anybody had the same problem with the ingnition module ( the one under the cap )!!
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Ari G
Dec 11, 2014 03:21 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
