89 iroz z with 5.0 tpi throwing 3 codes
Old Aug 5, 2010 | 08:50 AM
whitedragon99_9's Avatar
Hey my z is throwing 22, 33, and 44 codes which are all sensors but the O2, MAF, and TPS are all brand new so probably the MAP or does it have both the MAF and MAP sensors?
Old Aug 5, 2010 | 03:05 PM
fbody93's Avatar
Yes it does have a mass air sensor and a map sensor. Code 22 is tps voltage to low. Code 33 is map sensor out of range. Code 44 is O2 sensor lean exhaust. Did you clear the pcm after you replaced the sensors?
Old Aug 6, 2010 | 12:34 AM
cars3's Avatar
No map sensor on 1989 cars with TPI. 1989 TBI cars do.
Gtpguy
Jan 26, 2015 04:50 PM
Deadbolt24
Jan 19, 2015 01:29 PM
cmdeshon
Dec 27, 2014 10:06 AM
91Bird305
Aug 5, 2002 01:39 PM
