89 Iroc no power to fp or injectors
Old May 21, 2007 | 11:39 AM
NUTTNTOIT's Avatar
Hello,
I'm new to the sight,read alot of the post and have learned alot of good information. But I have a question about my 87 Iroc 305 tbi (yes tbi). I got the car about a month ago, the people before me had added a push button starter, the car would not start with the key. (The key has the chip in it.) The starter quit working,so I changed it. Now I have no power to the fuel pump or injectors, I checked fuses,relays, wires exc. Could the vat keep power form being supplied to injection and fuel pump? I have read about the vat bypass, and I am going to order a new chip for the ecm, I just want to know if this would fix the problem. I'm sure that I have left out some information,but maybe this is enough.
Old May 21, 2007 | 12:17 PM
Z28SORR's Avatar
Sounds like it was a VATS problem all along. It will kill the power to the starter also. Did you have the starter checked after you removed it?
Old May 21, 2007 | 01:03 PM
NUTTNTOIT's Avatar
I had it checked and the starter was bad.
Old May 21, 2007 | 05:12 PM
Wacky Tower's Avatar
Did you check the fuse holder next to the battery? I know TPI motors have one but I am not sure about TBI motors.
Old May 22, 2007 | 05:47 AM
NUTTNTOIT's Avatar
yes, I ran the wire from the fuel pump to the ecm, I ran a hot wire to the fuel pump (new)it works, but no power to injectors, so I think the may be on the same curcuit? thanks for all the info.
Old May 22, 2007 | 10:45 AM
Rice Killer87's Avatar
The ECM supplys the ground to activate the injectors,so it sounds like either a VATS or ECM problem.
Get the chip swapped out to get rid of the VATS and see where that gets you.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
dale3in98
Feb 14, 2015 12:18 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
