87 Iroc Gears.
Old Jul 18, 2005 | 07:47 PM
carlo1170's Avatar
87 Iroc Gears.
I have an 87 Iroc with 4.11 gears in the rear end. Will any gears be better than this? Can you suggest some for maybe some smoother shifts and just better overall Performance. It has a 350 engine in it.
Old Jul 18, 2005 | 09:13 PM
Dave89IROC's Avatar
Re: 87 Iroc Gears.
what trans?
what do you dislike about that ratio?
Old Jul 18, 2005 | 10:22 PM
carlo1170's Avatar
Re: 87 Iroc Gears.
Its the 350 trans.
I dont' really know, is there any other gears that are going to better me? it shifts a little rough, and it seems to kick back and forth a lot.
Old Jul 18, 2005 | 11:06 PM
Stephen 87 IROC's Avatar
Re: 87 Iroc Gears.
Depends what you want to do. My daily driver truck has 4.10 gear but also has 28" tall tires and an OD tranny. It's fun to drive stoplight to stoplight but even on the highway the rpms are still high. At around 60 mph, the engines about 2800 rpm.
For dragstrip use, gears are very important. They multiply torque to the wheels. You'll get more torque multiplication from 4.10 gears than you will with 3.73 gears. The extra torque can help get a heavy car with a low torque engine moving quickly. When properly chosen with tire height and peak engine rpm, you should cross the finish line at or just before the peak shift point.
The higher the HP the engine or the lighter the vehicle, the less gear you need in the diff. Very fast tubbed out cars may only have 4.56 or 5.13 gears but they usually also have tall 33" tires for traction.
If your car is a daily driver and only has a TH350 tranny, you'd probably be better off with 3.73 gears if your tires are only 26" tall. If you have taller 28" tires, 4.10 will be fine.
Old Jul 18, 2005 | 11:29 PM
carlo1170's Avatar
Re: 87 Iroc Gears.
wait a second. I have an OD tranny also. does the 350 not have OD? cuz then im wrong. it sucks because i didnt do the engine/tranny swap so i dont know. its a 4spd OD tranny. what do you think?
Old Jul 19, 2005 | 01:20 AM
SSnthe10s's Avatar
Re: 87 Iroc Gears.
that prolly a 700r4, they have a really steep first gear too,
Old Jul 19, 2005 | 12:15 PM
Tru2Chevy's Avatar
Re: 87 Iroc Gears.
Getting gear advice without telling us what you use the car for is pointless. Is this your daily driver? Do you drag race? Do you autocross? Do you road race? What is the engine and suspension setup?
We need more info before helping you out with your selection.
- Justin
Old Jul 19, 2005 | 11:27 PM
carlo1170's Avatar
Re: 87 Iroc Gears.
Sorry guys im new at this.
its a daily driver, but not so much. i dont drive very much. To and from work pretty much. which is 5 minutes away.
The Engine is a 350. I honestly don't know what suspension setup i have, considering i didnt do it, i will try to find out though.
and no, it is not the Stock TPI. its an Edelbrock Manifold and Street Avenger Carb.
Old Jul 20, 2005 | 03:18 PM
85_305's Avatar
Re: 87 Iroc Gears.
Originally Posted by robvas
If you're still running the stock TPI, 4.10's are too much gear IMO
Indeed Indeed. That TPI can't crank out the high-rpms that 4.10's love ever so much I would look into 3:73's.
Not to mention your car probably sucks gas like a **** w/ those gears. The ONLY time I would get 4.10's is if it was STRICTLY a track car, or you had a T56 to back it up
Old Jul 20, 2005 | 09:37 PM
carlo1170's Avatar
Re: 87 Iroc Gears.
yeahhh i am sucking on gas.
but no i dont have TPI. i have a Holley Street Avenger Carb with a Edelbrock Performer manifold.
Old Jul 20, 2005 | 10:58 PM
85_305's Avatar
Re: 87 Iroc Gears.
Really... now thats interesting
Hm.. even if you dont have the TPI, you still only have a 4spd which is why you are sucking gas. Upgrade that to at LEAST a 5spd if your keeping the 4spd, or put some 3.73's on there if your gonna keep your auto
Old Jul 20, 2005 | 11:10 PM
carlo1170's Avatar
Re: 87 Iroc Gears.
well its a 4 spd overdrive.
but yeah, i would love to do a tranny swap, but i dont really think i want to get into all that work. but. What are the 3.73's going to do for me thats better than me 4.11's?
Old Jul 21, 2005 | 02:30 PM
85_305's Avatar
Re: 87 Iroc Gears.
Basically your 4spd is making your car run out of steam long before having a 5spd or 6spd in it would. You will be going (these are NOT exact numbers.. just trying to give you and idea ) 60mph and cranking out like 2k-rpms w/ the auto. If you put a 5spd or 6spd in, you could be going 60mph at like 1k-rpms to 1200rpms. That is where your fuel-savings come in. Not to mention, your car w/ 4.10's prolly tops out at like 120, whereas w/ a 5spd or 6spd you could hit 20-30mph more than that (maybe even more).
Old Aug 20, 2005 | 04:44 PM
carlo1170's Avatar
Re: 87 Iroc Gears.
well the thing is, i really dont have the money for a tranny swap. so how bout them gears, what should i do?
and yeah your right about the speed. 120-130 is my best guess. should i get the 3.73s?
Old Aug 20, 2005 | 11:28 PM
85_305's Avatar
Re: 87 Iroc Gears.
Ya, 3.73's would be your best bet
