87 Iroc 305 Sputtering..on throttle
Old Mar 29, 2009 | 04:58 PM
  #16
azradrods99's Avatar
305 Sputtering and bogging in my end as well
86 Z28,
replaced the fuel pump, fuel filter, maf, ECM, full tank of Mobil gas and same ol crap. Bogs when I try to hit passing gear, need to feather it to get it back to working order.
One guy on this site said I had a bad cat. I guess I can continue replacing everything..................NOT.... Sounds like this is a sympton of the 5.0 TPI...
Anything to fix it?
New guy from Arizona
Old Apr 1, 2009 | 09:41 AM
  #17
sobo's Avatar
You talk about a week of &*((*&. Got it running good now. I'm not sure which one did it but I checked my vacuum lines and just made sure they were all connected well enough. I payed close attention to my egr valve. I took the line off of that and made sure it wasn't blocked. I connected it to the valve and blew some air into it. The valve may have been stuck.
I then took off my maf sensor, bought a 5.00 can of maf cleaner from kragen auto parts and sprayed that thing down.
Car is running ok now. I came really close to needlessly changing the fuel pump but luckily I waited.
Check these items first!
colts0455
Jul 8, 2015 12:21 AM
Amshnock
14
Jan 18, 2015 11:47 AM
