86 IROC High Idle help!
Old Feb 19, 2003 | 02:39 PM
TSP-MIKE's Avatar
I have an 86 IROC and the idle sits at 1800 Rpm. It just started one day. Any sugesstions?
Thanks, Mike
Old Feb 19, 2003 | 08:36 PM
yenkoz28's Avatar
I'd check your Idle Air Control motor and Throttle Position sensor.
Old Feb 19, 2003 | 11:29 PM
Scrote's Avatar
Is it a four barrel or TPI?
Old Feb 20, 2003 | 01:03 AM
wildcard's Avatar
Try unplugging your trottle position sensor while the car is running. If your problem goes away, change your trottle position sensor.
Old Feb 20, 2003 | 01:56 PM
TSP-MIKE's Avatar
It's a TPI 350. I'll check as soon as it stops raining and update on what i found. Thanks for the help.
Old Feb 20, 2003 | 02:16 PM
TSP-MIKE's Avatar
Update! I tried unplugging the Throttle Position Sensor while the car was running. Nothing happend. I also unplugged the IAC and still nothing happend. Is unplugging the IAC the way to check it? There are also a few other things that happend at the same time my idle starting to get high. When i hit my brakes the rear defroster turns on (wierd). Also my tranny used to run at 2500Rpm @ 70MPH, now it runs at 4500rpm @ 55MPh. But the strange thing is my trans is shifting through all the gears. OH and i have a 700r4.
thanks, mike
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
mark0006
Feb 28, 2015 07:12 PM
dawg irocz
Feb 10, 2015 10:33 AM
