86 IROC Computer help!
Old Mar 2, 2003 | 10:44 PM
TSP-MIKE's Avatar
Does anyone know where i could find a computer for my 86 IROC? The service number is 1227165. Also what usually goes wrong when the computer is bad?
Thanks, Mike
Old Mar 4, 2003 | 10:51 AM
Jim85IROC's Avatar
You can always find the computers on Ebay for around $50. Any TPI car (camaro, firebird, corvette) from 86-89 uses that computer, so they aren't hard to find. A computer failure could cause any one of a million problems depending on what failed. What problems are you having that make you think the computer is shot?
Old Mar 4, 2003 | 12:09 PM
TSP-MIKE's Avatar
Well for a while now the idle just kept rising everytime i start the engine. Before it was just 1500rpm now it's at 3500 Rpm idle. Then i was told that the computer some how controls my transmission too. Since i was going 60MPH at 4500 Rpm in overdrive. The other day i cranked it up and tried to check my tps and iac. Well when i tried to turn it on again all the dash lights were out, and even my car alarm didn't even work. I check all the fuses and they were fine. I tried to reset the ECM but that didn't work either. Yesterday i found a comp at the junkyard and installed it. everything came on again but it would not start. I pulled the chip off my old comp and stuck it in the new one. It cranked right up but didn't fix any of the problems i was having. I was messing around and plugged my old comp and the chip back in. It work too! So now i donno what is going on.
Thanks, mike
Old Mar 4, 2003 | 12:44 PM
krazzycowgirl's Avatar
go to the auto parts store & spend like $300 (yes I know its alot of money but it will save you money in the long run) & get a hand held scanner that does ALL Cars. Hook it up to your car & see what codes its putting out. My husband has a listing of all the GM codes on our website.
Believe me you will be better off in the long run.
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
