85 l98 300hp ????
Old Sep 19, 2003 | 03:52 PM
jbbiggs's Avatar
85 l98 300hp ????
Whats my best choice to reach 300hp with a 1985 l98, I will be pulling heads and cam,
1. cam choices?
2. will it need tuning?
3. intake mods?
I would like to keep it under 5500rpm if possible.
Old Sep 19, 2003 | 03:56 PM
Shaun 90 Iroc's Avatar
I seemed to get 300hp so far out of mine..
zz-4 cam
vortec heads
sdpc tpi vortec baseplate
will need tuning!
without proper tuning.. running really rich i got 252rwhp and 376rwtq
i also have slp 13/4th headers
Old Sep 19, 2003 | 04:01 PM
jbbiggs's Avatar
zz-4 cam
vortec heads
will need tuning!
Yours is a roller motor, do they make a comparable flat tappet cam?
I would like to switch to a roller if I could, use like a lt1 cam and lifters & get by cheaply .
Old Sep 19, 2003 | 04:06 PM
FerrMaro's Avatar
There was no L98 in 85'. i thought the 350 didnt come out officially till 1987?
Old Sep 19, 2003 | 04:09 PM
jbbiggs's Avatar
Re: ????
Shhhh!!!!!! it's in a vette........
Old Sep 19, 2003 | 05:24 PM
krazzycowgirl's Avatar
Re: ????
You are right but many of the 3rd genners have swapped out engines on their Tired 305s & 6s.
Old Sep 22, 2003 | 12:33 PM
Z28SORR's Avatar
One way! This was in an 87 Corvette.
401wrhp. ZZ4 350 short block, reworked L98 aluminum heads(bigger valves, 5 angle valve job, pocket port and port match), LT4 hot cam kit(1.6 rockers), 58mm throttle body, 24lb/hr injectors, adjustible fuel pressure regulator, High performance fuel pump(in tank), CAI, LPE/edelbrock superram air intake, Borla cat back w/high flow cat, and of course programming. Over $5,000.
But all was new so it could be done for less.
Also I would not do this combo today, better parts out there now!
This engine had excelllent idle, mileage, and was emissions compliant. I originally intended to do this with the 385 fast burn heads, but no TPI base was available at that time. It is now!!
Old Sep 22, 2003 | 03:24 PM
Jim85IROC's Avatar
the hydraulic cam won't matter much at the horsepower level you're looking for. Vortec heads, SDPC base and SLP runners should easily get you there with the right cam.
Old Sep 23, 2003 | 04:33 PM
jbbiggs's Avatar
What cam do you suggest? I would like keep the stock convertor
Old Sep 23, 2003 | 11:03 PM
aklim's Avatar
Get the best heads you can because they can be reused in a different motor. Vortech heads have to use one manifold only for TPI and they are heavier. Lighten front will help you launch a little.
Tarizza
Sep 20, 2015 03:26 PM
89 Iroc-z28
Jun 30, 2015 11:19 AM
InfernalVortex
Jan 17, 2015 09:35 AM
KASR_Z28
Sep 11, 2002 12:46 PM
