700R4 To Turbo 350 Swap !!
Old May 11, 2004 | 10:55 PM
shwine617's Avatar
I pulled my 700r4 yesterday and I have most of the parts for the TH350 swap.
B&M Holeshot 3000 Converter
B&M crossmember/tourque arm kit
built TH350
TCI sfi flexplate
all new bolts
I am just having trouble trying to find the right driveshaft. I need one that is 43" from center of U joint to center of U joint. The other thing I am haveing trouble with is the whole speedometer setup. The car has an electrical speedomter and the TH350 has a mechanical. I do have one of the older dash setups with the cable driven speedo from a 86 z28 but I don't know if it will fit or not. I am also stuck on what to do with the wires that were connected to the 700r4. Can I just zip tie them to the side?
thanks!
Old May 12, 2004 | 08:49 AM
trackbird's Avatar
I think Painless wiring has a speedometer conversion unit for you. Check with them or their website, there are a few of those around (if they are still around).
The driveshaft will probably have to be custom. You may be able to use the driveshaft from a 1982 Z28 with the 3 speed in it (I think that one will fit), but (even if you can find one) it is now 20+ years old and not real heavy duty so I'd probably not bother with it.
Good luck!
Old May 14, 2004 | 01:42 PM
GreaseMonkey83's Avatar
Ive been doin my homework lately on this subject since i am doing a 700r4->Powerglide swap. It seems that you have 3 choices when it comes to the driveshaft. 1)brand new custom driveshaft 2) 82 camaro with TH200 3-spd or 3) GM H-body driveshaft (Chevy Monza, Pontiac Sunbird, Olds Starfire, Buick Skyhawk). Im not 100% sure these will work, i was just told by someone that had done the swap before that it would. Im sure one of these cars would be easy to find in the junk yard so you take measurements from it if youd like and find out for yourself.
Old May 15, 2004 | 09:54 AM
82355's Avatar
I can vouch for the '82 Camaro TH200 driveshaft working with a TH350 swap.
Martin
dylan1303
May 22, 2015 12:24 PM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
veryslowfbody
Aug 22, 2002 04:31 PM
PROSTREET406
Jul 23, 2002 08:20 PM
