700r4 Trouble
Old Apr 12, 2003 | 02:13 AM
thezisking's Avatar
Question 700r4 Trouble
I have an 86 z-28 with a LB9 motor and a 700r4 tranny. The problem I have is when I put the car in drive, It runs down the road fine, shifts through the gears smooth, etc... But if I put it 3, 2, or 1, It won't go into gear. It moves very slightly, but for the most part it seems like neutral. I changed the transmission fluid and filter (did NOT flush) and still didn't help. Does anyone think flushing it would correct this problem? When I took off the tranny pan, the used fluid was pretty black. The pan had a steel gasket on it (factory fluid??). Thanks for any help!
Old Apr 13, 2003 | 08:57 AM
kjlvilla's Avatar
You may have a problem in your overrun clutch pack. It is only put on in manual ranges to provide engine braking. It is in the same housing the forward clutches are in. If your overrun clutch pack has a leaking seal, it may be bleeding off enough fluid to starve your forward clutches, causing a slip. If this is the case, flushing the fluid isn't going to help. Hope this helps.
Old Apr 13, 2003 | 07:38 PM
thezisking's Avatar
Do you think that it'll hurt the transmission as far as keeping it in drive? Thanks.
Old Apr 15, 2003 | 09:17 PM
kjlvilla's Avatar
I hate to say it 'will' not have a problem, but it shouldn't. As long as none of your other gears are slipping it is probably ok.
Ericksd
Jan 20, 2016 06:07 PM
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
Schul365
Aug 22, 2015 10:00 AM
Cam's maro
Aug 11, 2015 07:45 AM
