700r4 tranny.. what can it handle?
Old Mar 8, 2003 | 02:04 AM
Smokeyz28's Avatar
what can the tranny hold? a buddy has one.
it would be for my 454
Old Mar 8, 2003 | 02:45 AM
iroczinoz's Avatar
If built up it can handle what you want it to handle up to a point.
But from what I have heard stock ones that came on our cars start breaking up behind anything that produces over 400ft LBS of torque.
So that 454 will most likely kill it pretty easy if not built up to handle it.
Old Mar 8, 2003 | 06:12 PM
fbird95's Avatar
This is arguable as what the 700r4 can handle just like what the T-56 can handle. I think the simple answer is no. I got in a argument with a guy claiming his T-56 would hold up to a built 454 cause he would baby it and was building a crusier. I said if you never plan to see what you "built " 454 can do it will fine, but most F-body drivers like to test the limits every now and agian. I would go with a turbo 400 tranny for your 454.
Old Mar 8, 2003 | 10:12 PM
stevem's Avatar
if you want an overdrive i would suggest a 4L80 transmission the only problem is that they are pretty big.
Old Mar 8, 2003 | 11:33 PM
aklim's Avatar
With a 4L80, won't you need to have a standalone controller? Why not build up the 700R4 to make it do what you want? I got www.rosslertrans.com to do it based on a recommendation by Lingenfelter and have been happy with the work. Lasted 3.5 years with me beating on it every day with a LPE 383 motor.
Old Mar 9, 2003 | 01:01 AM
stevem's Avatar
the 4L80-E needs a controller not the 4L80.
i was just suggesting this because of what he said but i am also building up my 700R4
Old Mar 9, 2003 | 09:38 AM
CAJUN-Z's Avatar
From: from the land of Justin Wilson and Huey Long!
The most that I personally know of is around 550rrhp built. Hardened input shaft, etc. does the trick. Actually, most 200r4's are built from the factory have a higher rrhp rating. The sun shell and input/output shafts are hardened and the journal surfaces are wider and hd. ...Grand Nationals run them pretty sucessfully in the 11's...
Old Mar 9, 2003 | 09:31 PM
aklim's Avatar
Still, unless you are puting that much power to the ground, it would be easier to use the 700R4 that has been built up to hold the power and you also have OD.
Old Mar 9, 2003 | 11:26 PM
Sitting Bull's Avatar
Not to mention that killer 3.06 first gear vs the 4L80's 2.4.
football4life
Oct 4, 2015 07:48 AM
Jake Bialke
Sep 24, 2015 11:31 AM
tommalcolm
Sep 11, 2015 03:39 PM
92_RS_305
Sep 8, 2015 07:47 PM
Cam's maro
Aug 11, 2015 07:45 AM
