700r4 shifting high
Old Aug 23, 2005 | 08:47 PM
PapaSmurfz28's Avatar
700r4 shifting high
89 iroc with 700r4...the car is shifting extremely high. Tried adjusting tv cable makes no difference...whats going on? it feels really loose when in gear driving like it has a high stall
Old Aug 23, 2005 | 09:16 PM
gixxer92's Avatar
Re: 700r4 shifting high
Clutches are probably gone, burn to cinders. if it sticks in first and shifts at high rpm under light throttle and the TV cable is/was set then it sounds like it's time for a rebuild.
Old Aug 23, 2005 | 10:01 PM
yeah it seems fine at first until you expect it to shift and it doesnt until around 4k+ it shifts firm(enough to chirp with 275/60/15 Dr's) in 2nd and feels like the converter is stalling instead of dragging the car down like it normally would if you were holding it in 2nd let off the gas and tap it again...thanks gixxer92 once again!
p.s. this is the 3rd tranny the car has had first replacement was B&M then that was "built" by a local shop because it burned up...tranny doesnt have many miles since rebuild under 7k (i know the previous onwer)
Old Aug 23, 2005 | 10:11 PM
gixxer92's Avatar
Just keep in mind it could be other things, but the two times that I've had it happen to me it was burnt clutches and a loss of second gear (stall feeling).
Tony
Old Aug 23, 2005 | 11:17 PM
antoine's Avatar
maybe a stuck govenor
Old Aug 24, 2005 | 06:10 AM
gixxer92's Avatar
What does you Trans fluid look like and smell like?
Old Aug 24, 2005 | 08:06 PM
fluid doesnt look or smell funny ive burned up trannys before in my 95z...pulled the govenor out...the shaft that goes into the transmission was pitted alittle...im not sure how it works but the cylinder in the middle of it moved some what freely when i closed the 2 arms??? so i cleaned it up anyways no improvment....from what i remember this all started when i manually shifted kind of high by accident while car driving through a parking lot
side note...i can get into 3rd but i have do 70mph or so...not sure about overdrive
Old Aug 25, 2005 | 07:58 PM
tranny is shot...extreme amount of shavings especially on the magnetic drain plug it looks kind of like a wire wheel now...also some large metal shavings
Apr 16, 2015 09:57 AM
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
