700r4 problems
Old Mar 3, 2004 | 11:11 AM
camaro craig's Avatar
700r4 problems
my automatic tranny im my 88 camaro is leaking transmission fluid all over the place, is there any common problems related to this because i cannot find the leak and info would be helpfull
Old Mar 3, 2004 | 01:43 PM
Marc 85Z28's Avatar
It could be the front pump seal, the trans pan gasket, the trans fluid fittings, the vent hose, the dipstick tube, the tailshaft housing gasket, the tailshaft seal, speedo cable area, tv cable area, etc etc. The only way to find out is to clean it all off and then run it. Check for the leak.
Old Mar 3, 2004 | 06:11 PM
dj haf's Avatar
i started to notice a small leak comming from the pan... ended up being my gasket
Old Mar 3, 2004 | 07:27 PM
TheGreatJ's Avatar
A sudden, major leak will usually be the front pump or dipstick grommet, or possibly a broken cooler line. Pan gaskets/tailshafts/TV cables/speedo senders tend to start slow and get worse over time.
Old Mar 4, 2004 | 10:20 AM
aklim's Avatar
Jack the car up, clean it off and run it while you observe from below. If this doesn't work, get a blacklight and add dye to the tranny fluid.
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Jan 30, 2015 09:21 PM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
