7 5/8 disc rear in 86 Iroc
Old Jul 27, 2003 | 03:15 AM
  #16
12Second3rdgen's Avatar
Originally posted by Momar
Yes the cover will have 10 bolts and the 9 bolt cover will have 9. This is not however where the number usually comes from. It is supposed to refer to the number of bolts that hold the ring gear. The 10 bolt has 10 bolts that hold the ring gear to the carrier. The 9 bolt goes against this idea and has 8 bolts that hold the ring gear to the carrier so it is technically an 8 bolt, but people just call it 9 in reference to the number of bolts on the cover.
Ben
Is this true with a 12 bolt too?
Old Jul 27, 2003 | 03:23 AM
  #17
Momar's Avatar
As far as if the car is stock, I wouldnt worry about it other than the better brakes from 89 up. If you are putting out some decent power or plan to it is not a bad option. I picked up my 3.45 9 bolt from an 87 GTA for 375. I couldnt leave well enough alone though so I upgraded to the 89+ brakes. LOL. I am going to be putting a t56 in this weekend so I may step up the gears soon. Over all it just depends on what your plans are for the car. If you are going to be putting out massive horsepower and have a wallet to match there is also 9" rears and 12 bolts to choose from. Miles(from 9bolt.com) has a 500 hp 427 in front of his 9 bolt and it has been fine for a few years now. He is also working on making some heavy duty parts for them too so they are definately an option if you are going to make more power than the 10 bolt will hold.
Ben
Old Jul 27, 2003 | 03:39 AM
  #18
BrianI's Avatar
The car has a tired 305 and I will prolly put a 355 in it in the future. I would like to have a rear that would hold with drag radials.
Will my existing brakes bolt up to a 9 bolt or would I have to use the 89 up disc brakes?
Old Jul 27, 2003 | 03:48 AM
  #19
Momar's Avatar
Your existing brakes will work on a 9 bolt as long as it is from 85-88. If it is from an 89 you will have to get different backing plates for the brakes but they can still be used.
Ben
mark0006
Feb 28, 2015 07:12 PM
dale3in98
Feb 14, 2015 12:18 PM
dawg irocz
Feb 10, 2015 10:33 AM
rockync7
Jan 1, 2015 05:10 AM
