5 way harness help
Old May 12, 2004 | 12:53 PM
1984camaroz28's Avatar
5 way harness help
Need help on what type of harnes i need for my car. I have aftermarket corbeau seats in the car but no roll cage yet. What type do i need individual or Y-type. What is the diff
Old May 12, 2004 | 02:14 PM
trackbird's Avatar
I would not use a harness without a roll cage. If you do roll it, you can't lean into the center console area to avoid the roof (as it is crushed in). If you can't lean over and the roof caves in, your head gets to support the roof. Not healthy. Also, the cage gives a proper attachment point. If you attach the belt too low (at too much of an angle) and are in a front impact collision, it can cause spinal compression injuries (crush the spine downward, causing serious injury). If you decide to run the belt to the rear "deck" area, remember that these belts are designed for a controlled stretching during an impact. Too much belt length and you may hit the dash/steering wheel before the belt stops your forward motion.
Just my thoughts.
Be safe!
Old May 12, 2004 | 06:27 PM
TheGreatJ's Avatar
Trackbird's got you on the right path here. The shoulder belts of a 5-point are supposed to mount at shoulder height as close to the seat as possible.....i.e. on the crossbar of the roll cage. Get the cage first then worry about the 5-points.
Old May 13, 2004 | 12:08 PM
Z28SORR's Avatar
This depends on the sanctioning body for where you are racing. Check their rules. Some allow either Y or Individual, and some require the individual type.
G-BODYT56
Jan 14, 2022 11:14 PM
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
Thirim
Jul 30, 2015 01:29 PM
RUNMYTA
Jul 15, 2015 07:50 PM
