3rd gen diet
Old Mar 18, 2003 | 12:01 AM
IgorT.455/406's Avatar
3rd gen diet
Hey guys. I need to make sure my car looses some weight this year. It will have aluminum heads, intake, wp. I am planning on loosing the A/C, batt is going in the back, and a few more little things. What else can I do to shed some weight? I want to keep the car streetable and I want to keep my door panels and dash. Rear sets and hatch padding can go, but carpet nad pass. seat must stay. No subwoofers or amps will be left in the car, just deck and 4 spks. Any input would be great. thanks guys.
Old Mar 18, 2003 | 12:15 AM
Capriceforever's Avatar
get 1LE driveshaft
get lighter wheels
Old Mar 18, 2003 | 12:34 AM
L98-Z's Avatar
I'm bascially trying to do the same your doing... or plan to before long. Here's what I've came up with.
Take AC off, Smog, Air pipes, and everything related to AC.
Convert to Manual Steering from S-10
Convert to tubular control arms and K-member, also coil overs.
Move the battery to the back.
Take wiper motor out, washer tank, and washer pump
Remove both front and rear sway bar
I plan to probably do all of that, but it won't be a daily driver. It'll be a weekend car probably.
If you really want to do some reducing of weight, you can cut the braces out of your doors (I would recommend you have a roll cage before even thinking about it), taking the honey comb out of your bumper, anything that can be taken off will be taken off.
Just some ideas for you.
Old Mar 18, 2003 | 02:15 AM
stevem's Avatar
fibreglass or carbon fibre hood
shorten the exhaust use lighter pipe(exit before rear wheels)
CLEAN YOUR CAR dirt weighs alot
smaller more efficient rad
smaller alternator(saw one in a mag that weighed under 6 pounds.
convert to serpintine belt(if not already)
you will need a different wp if you convert to serp belt.
aluminum motor$$$$$$
remove body kit if your not concerned with looks
headers
remove fog lamps
remove all that plastic in front of rad(i did to install my ram air behind my fog lamps)
HOPE THIS HELPS
Old Mar 18, 2003 | 11:38 AM
camarocruzin's Avatar
http://www.thirdgen.org/newdesign/te...ngpounds.shtml
Check it out
Josh
Old Mar 18, 2003 | 11:52 AM
87DJP2001's Avatar
Also if the Driver is over 200# he should lose some weight.
14
Aug 11, 2015 12:03 PM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
cmsmith
Jul 10, 2015 07:19 PM
cmsmith
Jul 5, 2015 07:23 PM
