396 out of an L98?
Old Oct 2, 2003 | 05:31 PM
mako350Z28's Avatar
396 out of an L98?
I was throwing around some ideas for a project for next year and I thought, would it be possible to bore an L98 .060 over and stroke it to a 396?
It would require a bore of 4.06 and a stroke of 3.82. Has anyone ever heard of this being done? If so, what kind of power does that put out?
Old Oct 2, 2003 | 05:37 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Most people do it with a .030 motor and a 3.875 crank. Its actually fairly common. Though Im not sure if its done often with an L98 block.
It will put out poswer numbers similar if slightly better than a 383 built the same way. However the crank needed is only avaliable in steel. So you will have to shell out the extra cash for that. No cast models.
Old Oct 2, 2003 | 06:05 PM
AutoRoc's Avatar
Usually I see the "396" done with a 4.030 or 4.040 Bore and a 3.875 stroke. The smaller bore is actually 395, the larger is 397 but who's counting?
As far as what power it makes..."more than a 350" is all you can really say. More cubes makes more power if all other parts are identical. More Air+More Gas=More power and adding bore and stroke can accomodate that Goodluck!
Tarizza
Sep 20, 2015 03:26 PM
89 Iroc-z28
Jun 30, 2015 11:19 AM
pimpss96
Feb 12, 2015 01:28 PM
