383 to a T-5
Old 01-20-2003, 05:10 PM
Chris`s85Z28's Avatar
383 to a T-5
Well I know the T-5 is not the best tranny but will it have any chance behind a 383 ci 400hp engine
if I can get the 383 done by summer it will have to go in front of the 383 the T-56 is next winter`s project
The car is a 85 Z28 with no modds except for the engine and I wont run slicks just my 255/60R15 Good years
Will the tranny hold if I don`t dump the cluch?
SFC`s will be installed before the 383 goes in
Chris`s85Z28 is offline
Old 01-20-2003, 06:41 PM
jd13's Avatar
If you don't abuse it, ie no WOT throttle runs or clutch dumps, then it might last for a month or two. A t5 doesn't have a chance against even the most midly built 383. A t5 couldn't really handle an L98 (350).
Now of course you can build it up real nice, but it still won't last, and in my opinion, won't be worth it.
jd13 is offline
Old 01-20-2003, 07:21 PM
ZZ430RS's Avatar
I'm running a WC T-5 behind my ZZ430, I went and rebuilt it and made a few custom parts for it that I read would really help the strength of it, it's still going strong 6 months later and I don't take it easy on it, but I don't power shift it either, that's what really kills them. When and if it ever fails I'm getting either a T56 or Tremec.
ZZ430RS is offline
Old 01-20-2003, 10:29 PM
wasted420's Avatar
i had a WC t-5 behind my 383 nitrous motor with a center force dual friction clutch and i beat the living **** out of it with no problems
wasted420 is offline
Old 01-20-2003, 10:50 PM
Irocvette355's Avatar
I have a t-5 bolted up tp my 355, I drive hard on it and it seems to be fine. Its been rebuilt once, just for safetys sake.
Irocvette355 is offline
Old 01-20-2003, 11:49 PM
87ROC's Avatar
Don't be tempted by sorry 60 ft. times at the strip and it will probably last. Didn't see if it was WC or not. If you tires don't hook up then dumping the clutch probably won't kill it either. My 305 killed my non WC when I dupmed the clutch from a 20 mph roll in second. My WC has help up well behind my 350 for a while now. But I have really bad tires and don't dump the clutch.
If you ever want to pull sub 2 second 60 ft. times you may run into problems.
87ROC is offline
Old 01-21-2003, 05:14 PM
It`s not a WC and I don`t plan on racing it till I get the T-56 put in I just wanted to know if the T-5 will last 5-6 months if I don`t abuse it to much
I`ve dumped the cluch at 3000 rpm`s with the 305 and it did fine
and if I don`t get the 383 done this summer it won`t matter because the Zed will have a T-56 in 2004
and is there a way I could put a M-22 behind the 383 in my Zed I thought it would be cool to have the 4 speed like the older camaro`s
Old 01-21-2003, 06:32 PM
ZZ430RS's Avatar
82 Camaros came with 4-speeds and mechanical linkage, all you have to do is locate all the parts.
ZZ430RS is offline
Old 01-21-2003, 11:15 PM
I EAT T/A's Avatar
I've been wondering the same question.
I have a 305/T5 car right now and will be droping my L98 in it soon. The motor will be stock, so I don't see any problems with it.
I EAT T/A is offline
Old 01-24-2003, 09:30 AM
fbird95's Avatar
400 hp and a t-5, wow i surprised you guys aren't having more trouble with the T-5. If we recall GM built 50 86' Irocs with a 350 and the T-5 and it killed the T-5 all the time. Then in 87' when the 350 tpi became available, it was only availible with the auto tranny because the torque of the tpi killed the T-5. All the T-5 cars could only have the 305 tpi.
fbird95 is offline
Old 01-26-2003, 12:15 PM
Z28SORR's Avatar
I have an 84 with a 383, 390hp, & 411lb' of torque. My T-5 has lasted many years and was still going strong when I put the T-56 in.
Z28SORR is offline
Old 01-26-2003, 02:36 PM
Duke's Avatar
My 327 and my 305 ate T-5's, lets see how long it will live behind my 377
Joe
Duke is offline
Old 01-26-2003, 05:56 PM
brodyscamaro's Avatar
ever dump the clutch? ever run slicks?
actually to all you guys with 350+ cubes could ya answer that question
brodyscamaro is offline
Old 01-27-2003, 01:45 PM
Z28SORR's Avatar
brodyscamaro,
No slicks. But I was running Yoko's 315X16 A008R's asymetrical's.
I did not "baby" the car but also didn't do any 6 grand clutch dumps either.
I don't think anyone is suggesting that this is any kind of bullit proof trans. Only that it will last if you take it a little eeeeazy.
I also think there is a bit of luck involved, re. the horror stories.
Z28SORR is offline
Old 01-27-2003, 10:27 PM
ZZ430RS's Avatar
I think most people know not to dump the clutch with a T-5 and I don't run slicks either, I just use it for street use, I'll usually leave at around 2000-2250 and slip it just a little, then give it all it has, and no power shifting, and just because you have a T-56 or Tremec don't think you can't break it, I've seen several of both get destroyed behind mild engines if they are abused or the driver doesn't know how to shift.
ZZ430RS is offline
Quick Reply: 383 to a T-5
