36, 38, or 42 lb Lucas injectors for new 383?
Old Oct 22, 2004 | 09:31 AM
Anniversary-Z-man's Avatar
Well I had Bosch injectors on the last engine so I figured I'd try out some Lucas ones this time. Anyways the 383 dynoed with a carb at 532hp/482lb ft at the crank....now it's Minirammed with a new Walbro 255 fuel pump. PROM tuning will all be done by myself....gonna hafta learn alot!! She's a nice day, weekend car that'll be taken to the track occasionally. The guy at Racetronix says to go with 42lbs running them at 80%....I did the calcs too and it seems like that's the case....although it seems alot of people with 383's (with 400-450hp) are running only 30lb injectors.....
PLZ help....Seems all the formulas point to either 38 or 42 lb. ones....
- Joel
Old Oct 25, 2004 | 07:30 PM
onefastgta's Avatar
Re: 36, 38, or 42 lb Lucas injectors for new 383?
I use the 36's and the duty cycle is 75% at it's highest.
Old Oct 25, 2004 | 07:42 PM
klumb15's Avatar
how are you gonna do the prom tuning yourself??? dont' ya need a bunch of hi tech equipment??
Old Oct 25, 2004 | 08:01 PM
onefastgta's Avatar
the equipment is not high-tech, it ain't rocket science.
just takes some patience.
Old Oct 25, 2004 | 08:03 PM
klumb15's Avatar
WELL LET ME IN ON SOME KNOWLEDGE!!! that is the only thing holding me back from modding my FI setup, i don't want to pay 500 bucks for someone to tune my computer!! if its top secret heres an email address klumb15@hotmail.com
Old Oct 26, 2004 | 12:13 AM
aklim's Avatar
I am usin 42 with my 383 and a HSR. This goes thru the A4 making 410 HP at the wheels.
www.fasterproms.com will do the first burn for $350. After that, it is $150 for each burn. They can lend you their software to hook up a laptop to the car and make the road your dyno.
Old Oct 26, 2004 | 12:26 AM
Racetronix's Avatar
All you need:
http://www.tunercat.com/
http://www.ttspowersystems.com/diagnostic.htm
Old Oct 26, 2004 | 08:20 AM
383Z's Avatar
I used 30's and mine ran great with a SR setup but i would go with what racetronix says he's pretty knowledgable on fuel setups.
Old Oct 26, 2004 | 09:13 AM
aklim's Avatar
I am using 42 on mine now with a 383 and HSR setup and making about 410 HP at the wheels.
Old Oct 26, 2004 | 09:41 AM
WS Sick's Avatar
I'm using 30 # SVOs, that when mated with GM fuel pressure levels are closer to a 32 # injector. I trap in the 1/4 at 115 to 116. each run @ 1500 feet elevation, 3600 # car. The math says I'm making over 415 RWhp.
While a freind was working on it with his equipment he said at 6400 rpm (shift point ) they were just over 80 % DS.
My motor is a 10.5 :1 compression motor. (5.7 rod)
Old Oct 26, 2004 | 05:36 PM
Zepher's Avatar
Originally Posted by Racetronix
don't forget about this,
Old Oct 26, 2004 | 05:58 PM
klumb15's Avatar
carb seems easier
Old Oct 26, 2004 | 06:04 PM
383Z's Avatar
But there is something extremly cool about getting decent gas mileage being able to drive it on the street legally for us emissions people and still run 11's and 12's in the quarter.
Old Oct 27, 2004 | 08:50 AM
WS Sick's Avatar
Where do you get that pocket programmer? I have tunercat, but have to erase and flash and solder with my set-up, so it doesnt get done like it should.
Carbs are finicky, crap my old pick-up with a holley has to be retuned everytime the weather takes a major change.
Old Oct 27, 2004 | 08:56 AM
I bought my pocket programmer from Craig Moates with extra chips etc. a couple years ago....
- Joel
