350 w/manual transmision
Old May 20, 2003 | 07:10 AM
  #46
Jim85IROC's Avatar
Originally posted by camaro6
There is no ZF6, its the MN6. GM uses Z RPOs for Z24, Z28, Z34, Z78, ZL1, ZR1, not transmissions.
I think I need to stop coming here.
ZF6 is the name of the transmission, not the goddamned RPO code. fbird95 posted the full-length german name above that I'm not wasting my time to cut & paste.
What are they testing for? Extra weight? Why would they test a 350 ci, in an 86 car? The engine they suposibly tested in the 50 86' IROCs that as you claim were all automatics had 220 hp. In 85' the LB9 enigine put out 215 hp. Then in 86 its breathing was clogged back up and the LB9 had only 190 hp. Your telling me GM would spend all that money to build and test 50 cars that had 5 more hp.
I dont think so.
GM tests every single drivetrain combo before it gets to production. Why WOULDN'T they? I'm sure they even had a bunch of 2.8 prototypes in 84 to test the upcoming MPFI 2.8s, and they sure as hell knew those weren't going to overpower anything.
Since the L98 in the f-body was sufficiently different than what went into the Vette, I'm sure there were plenty of issues that needed to be tested. Pistons, heads, cam... those were all different. Now you put that in a different car, and the PROM tuning would need work. Emissions testing and tuning would be another reason. There's a million reasons why GM would need to test that car before they put into production. They don't just put a plan on paper one year and produce the car for sale the next. Nothing goes out the doors without significant testing.
Old May 20, 2003 | 01:30 PM
  #47
fbird95's Avatar
You have a damn good point, And the bottom line is your right.
Old Jan 6, 2013 | 11:27 PM
  #48
ttompkins35's Avatar
Re: 350 w/manual transmision
I have a 91 with a swapped 350 crate motor and a t5 in it. they are hard to find but not that hard to swap. Mines for sale if your still looking for one, its very clean with no rust at all. The T5's bolt right on to the 350 without any adapter, to settle that disagreement
Old Jan 7, 2013 | 12:43 AM
  #49
cars3's Avatar
Thread is almost 10 years old since any activity!
Old Jan 7, 2013 | 01:51 PM
  #50
6SpdLT1Z's Avatar
Originally Posted by doug791
im going to be a pain in the *** and point out the fact that there was one year where they made like a hundred with a 5 speed and then scrapped the idea but we all know youre not exactly going to find one of those on autotrader
Don't forget the 92 firehawk.
That being said, the VAST MAJORITY of V8 3rd gens with manual transmissions are aftermarket swaps.
Old Jan 21, 2013 | 07:44 PM
  #51
hwcoll95's Avatar
or home builds
Old Jan 23, 2013 | 04:04 PM
  #52
birdman11's Avatar
Originally Posted by IZ28
Its funny though, I know dudes with swapped T-5's and L98's and they are OK.
If anyone wants a custom chip for a thirdgen ,let me know. I burn custom chips for Corvette and F-body's. I do have one ready for a 1990-92 350 tpi with a 5 speed transmission swap.
HAWG
Sep 25, 2015 11:41 AM
MDZ28
Sep 7, 2015 09:16 PM
Rittmeister
Aug 7, 2015 01:13 AM
alphaauto
Jul 26, 2015 04:40 PM
