350 TPI Fuel Injectors
Old Jan 14, 2004 | 07:31 PM
wildcard's Avatar
Question 350 TPI Fuel Injectors
I have heard that there was two different size fuel injectors between the 305 and 350 TPI's. Is this true? If so, what size came on the 350's?
Thanks, Ben
Old Jan 14, 2004 | 07:35 PM
Black6SpdTA's Avatar
LB9's (305) - 19lb/hr
L98's (350) - 22lb/hr
Old Jan 14, 2004 | 10:25 PM
trackbird's Avatar
If you change your 305 for a 350, you can add 3-5 psi of fuel pressure and use your 305 injectors. But, the 305 injectors are only good for about 350 hp, the 350 injectors are good for about 440 hp. So, if it is an "extreme" 350, you may need to consider an upgrade.
Have fun.
Old Jan 16, 2004 | 10:13 AM
aklim's Avatar
Or you can get the Ford ones that are 24 pph ones, and run stock pressure if you have a MAF. That or get the EPROM redone.
linz
Oct 22, 2015 07:59 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
4586
Dec 6, 2014 05:20 PM
Lederman1976
Nov 30, 2014 05:21 AM
Jul 4, 2005 05:00 PM
