350 fit into a 305.....
Old Apr 29, 2006 | 10:26 AM
  #16
91Z-28's Avatar
Re: 350 fit into a 305.....
Originally Posted by s10er8
Actually technically that's not true, the 400 blocks have a few differences outside the block
The external dimensions are still the same, so it wouldn't effect the swap.
Old Apr 29, 2006 | 11:37 PM
  #17
Camaro_Boy's Avatar
wow powerful words...
u must really have nothing better to do then cry on here... u lead a boring life my freind!
Old Apr 30, 2006 | 01:39 AM
  #18
84firebird's Avatar
ok fighting needs to stop, man in need of help and we all learned sometime (well most of us did, the guy who says it shouldnt be attempted obviously never learned), atleast camaro_boy's smart enough to ask before he starts, instead of 'uh...$!$#@, what happened?', and seriously online fights are sad... and on my 21 (ooops 22) year old firebird i have hobbyist plates and never have to pay registration anymore so ... anyway,
I have a one piece rear main 305 i stole a flexplate off of when i screwed up the 71 350's and it bolted up just fine, i did some research and found out why... it has little to do with the rear main seal, just years and not even really years just some are specified..., in my research 86 up to 95 have a different pn in a couple brands, but not all, for instance TCI and CSR have flexplates for all chevy, varying in tooth count, since well it matters for the starter gear lining up correctly, thus make sure you have the right starter for the flexplate this thread on another forum will assist in proper ID immensely http://www.jalopyjournal.com/forum/p...ad.php?t=42904 , the crankshaft is the crankshaft, pick up a summit catalogue, and sit back down.
next order of business, the big blocks are gonna be a tight fit, but i have seen it in stories , remove all the excess crap and they fit, just they K.O. your stock shocks and move the weight beyond your engine mounts, the mounts are the same, the external dimensions are not (have fun fitting bbc headers on the monsterously wide block, it's enough fun with small SBC headers), in that case (dimensionwise) SBC is the same as far as you need to worry yourself with and BBC is.... really big, however with any swap you need to clearance for it, this should be expected as wires need to be rerouted and stuff moved, if you need a sawzall (if you need one of these going with your 350... i'd get scared fast), but make sure you know what you're doing.
if you use different brackets for accesories that set out further from the engine you're probably going to have to set your radiator back farther into the front end of the car, in a big block... have fun figuring out where to put it.
however to the point 305 and 350 are the same size block small, and will swap easily, and for the next wiseass this is unless you are running a 'police interceptor' 350 and the starter takes up the entire area you intend to use for exhaust, and make sure that if you run a non stock oil pan, that you're careful, stock is a tight enough fit.
Old Apr 30, 2006 | 02:09 AM
  #19
84firebird's Avatar
Originally Posted by Blue89Bird
yes it is. Thats what it's there for. This isn't exactly some advanced topic that hasn't been covered at least a hundred times over the last few years. Spend 30 seconds and search and it will keep you from posting 15 topics on the same stupid crap thats already been posted and thoroughly answered.
and.... in 30 days the forum dies and nobody ever comes back to it, well said...well said.... search is good for problems that are exactly the same, but when you have slight differences, or less than 2 hours to spend at a computer, posting is much easier, people that know enough to help and post meaningful information other than complaints are more than happy to help, i would suggest an 'advanced topic' such as swapping a motor to you blu89bird, that way when you post, you'll have a clue as to what's being discussed
changing motors is advanced, along with transmissions, rearends and rebuilds of engines rearends and transmissions, which reminds me, you probably should consider rebuilding the 350, i mean while it's out, it's half the job already done. just a thought and if you need help with that post in classic or 3rd gen forum and i'll see it and help ya out
and i apologize for giving in and saying something, but i had to
Old Apr 30, 2006 | 11:37 AM
  #20
Camaro_Boy's Avatar
haha wow! its very true i think. i did read a few other posts online before posting but i wanted a personalized answer i sappose to to cover my I's and cross my t's. thanks alot for everything guys. that was awesome!
Douglas
I appriciate all the help!
linz
Oct 22, 2015 07:59 AM
1963SS
Feb 6, 2015 10:05 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
