32lb injectors to big ?
Old Sep 22, 2003 | 06:05 PM
slow_roc's Avatar
im buidling up a 350 plan on getting custom chip burned running a lt1 cam with 1.6 ratio rockers and vortec head with high flo runners would a 32lb injector be to big or jsut right 32 lb injectors would support 400hp if not 32lb i was thinking 24lb but maybe those are to small for over 350 hp ?
thanx steve
Old Sep 22, 2003 | 06:35 PM
NastyCamaro's Avatar
32lb are too big , go 24lb
Old Sep 22, 2003 | 09:43 PM
aklim's Avatar
My 383 is supported by 24 pph. Unless you have plans to SC or Turbo, I'd go with 24 pph
Old Sep 22, 2003 | 10:05 PM
slow_roc's Avatar
whats your 383 with 24lb run and what kind of pwoer dose it make u still running stock tpi or aftermarket intake? thanx
Old Sep 22, 2003 | 10:34 PM
aklim's Avatar
It runs mid to high 12s. Supposed to make 450 HP according to the specs LPE gave me. Running Accel SR intakes.
Old Sep 23, 2003 | 03:53 PM
Z28SORR's Avatar
350ci., 401rwhp, 24pph injectors.
Old Sep 23, 2003 | 11:00 PM
aklim's Avatar
I am not sure if that big an injector might make it hard to idle the car. You would have to shorten the pulse width so much that it may not be a stable idle.
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
titanthomas
Apr 18, 2015 11:44 PM
