305's Internally Balanced?
Old Aug 2, 2003 | 11:21 PM
Black6SpdTA's Avatar
Today I was talking to a buddy and he said my LO3 was externally balanced. I could have sworn they were internally balanced. Who's right? Other than the 400 SBC, what motors were externally balanced? Thanks
-Rippin
Old Aug 2, 2003 | 11:50 PM
Z_Ghost's Avatar
All the one-piece rear main seal small blocks have a counter weight on the flywheel or flex plate.
The machinist said he needed the flywheel to balance my 305 motor because it has the last counter weight on the flywheel instead of on the crank like the 2 piece rear main seal cranks do.
It’s still internally balanced motor.
Old Aug 2, 2003 | 11:57 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Yea its internally balanced, but the crank is slightly different than a 350 crank of the same era. If you take a 305 crank and lay a straight edge across the macined portion of the crank it will hit the crank on all of the humps. It wont hit every one on a 350 crank
Old Aug 3, 2003 | 02:59 PM
Damon's Avatar
MOSTLY internally balanced. The flexplate on these motors (305 and 350) has a "batwing" counterbalance on it that makes it NOT QUITE totally internally balanced.
I know, I know, it drove me nuts, too, but that's how they were made.
68camaroboltz
Oct 5, 2015 01:46 PM
Tarizza
Sep 20, 2015 03:26 PM
Daluchman1974
Sep 11, 2015 06:12 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
