305 tpi went 13.55 today!!
Old Nov 15, 2004 | 08:47 PM
  #16
guywidiroc's Avatar
Re: 305 tpi went 13.55 today!!
Yea, I can elab a little more on the setup for those of you who asked. Got some basic things like alum water pump, adjust fuel pres reg set at 47 psi. 170 deg thermostat, power pullies, stage 2 chip, headers, ypipe, 3 inch cat back, I ported the runners and plenum myself, ....but the launch is where the time comes in. I have nitto drag radials set at 15psi, tubular control arms, panhard rod, and poly bushings. Basically do a 8 sec burn out and launch at 4k. It hooked up for a 1.90 60 ft for the 13.5, but that was the best launch. The t56 has a 2.66 first gear, and my rear end is still the stock australian 3.45. Basically my launch and torque get me the time, and the best trap of 101 is just from having cold air and a healthy running 305. B&m ripper shifter is the best thing i ever did, aside the spec stage 3 clutch. my friend might have that run on tape, but i know the 13.6, and 13.7s were on tape. Either way, the 305 really loses its gas in the highend, and i still hate this motor compared to the ls1. But my best trap of 101 is high when i look at other 305s...but then i see these monkeys driving horrible 2.3 60 ft times and all. im gonna be at lapeer 3 more times this year if any locals wanna meet.
Old Nov 15, 2004 | 08:55 PM
  #17
guywidiroc's Avatar
Oh yea, i forgot for the one guy....full interior. Its a hard top, not a heavy ttop car, with spohn sfcs, and no power seat, no spare tire. Only options i have are power wind, power lcks, ac. I want to go weigh it at one of those truck stations.....think they will let me? Im guessing about 3350 or so.
What kind of 60 fts do you guys get with bf drags??? can i improve my 1.90 60 ft with a pair of them???
Old Nov 15, 2004 | 09:50 PM
  #18
Rice Killer87's Avatar
awsome,nice times for a 305.
Old Nov 16, 2004 | 08:00 AM
  #19
87DJP2001's Avatar
What with what this guy listed, for sure its BS......No 305 TPI with those so called Mods is that fast.
Old Nov 16, 2004 | 09:21 AM
  #20
teke184's Avatar
here is an old site with a TPI car with minor bolt ons running mid 13's
his site was the first performance site i found when i got my 87 IROC back in 97.
he got some very impressive times...stock internals
so it is VERY possible...lots of torque and good traction
Old Nov 16, 2004 | 10:45 AM
  #21
96m6lt1's Avatar
very good but the problem here is askulte has done great tuning,hedders etc.did you notice he also still uses the t5 tranny,which is waaayy lighter than the t56 and also uses a steeper 1st gear than the t56 its totally possible that the car ran the time claimed but to be that much faster than askultes, not really feelin that one,i am not tryin to be a" richard cranium" but i dont think the clocks were correct for his run,i mean a friend of mine with a marauder(fords attempt to copy an impala)ran back to back 15.70 then all of a sudden he pops off a 14.2(no mods)4 days old!it looked just as slow as the other passes sorry rob!
Old Nov 16, 2004 | 10:59 AM
  #22
slimdawson's Avatar
Hey, my RS runs 111-112mph in the 1/4 with just bolt ons! Of course it isn't an LO3
I get a lot of bs flags too but I have come to expect it. You should too with a car that runs like that. If everything is as you say it is, good job on the times. It is nice to see these cars run like they should.
Old Nov 16, 2004 | 01:42 PM
  #23
teke184's Avatar
actually...other than the hypertech chip...he didn't do any tuning on the car for those runs.
he did tuning after the turbo.
and yea the t5 is lighter, but that isn't gonna make THAT much difference. he also had a 9speaker sound system!!
Old Nov 16, 2004 | 02:28 PM
  #24
Marc 85Z28's Avatar
Still, that time is a little hard to swallow. GMHTP has been doing a buildup on a 89 Formula G92 good cammed 305 like yours (code named Blue Thunder), with the factory 5 speed and 3.45 gears. They did nearly identical mods, runners and ported plenum, pullies, headers and full 3" exhaust, among other minor stuff. They needed slicks and ideal conditions at a very good track with a good driver to just barely hit 13s. They weren't running over 100mph though, and all testing done near sea level.
If the times are legit, definately get videos! You'd be a legend amongst the 305 crowd Many people dog the 305, and those that do try to mod and go fast usually fail. Personally, I'd love to see a little 305 TPI running mid 13s on bolt-ons!
Old Nov 16, 2004 | 03:53 PM
  #25
Zepher's Avatar
From what I gather, he had these mods when he ran a 13.5 @ 103
Items in Red are the main mods.
* SPD Ram Air
* 52mm Throttle Body
* Portmatched TB, Plenum, Runners, and Manifold
* K&N Airfilters
* TPIS Airfoil
* Removed MAF screens and Fins
Engine
* Hypertech Thermomaster Chip
* 160 Degree Thermostat
* Accel 300+ Ignition System and coil
* SpiroPro 8mm wires
* Rapidfire Plugs
* SPD centerbolt valve cover plug wire holders
* Crane Adjustable Fuel Pressure Regulator set to 42 psi
* !A.I.R.
* !EGR
* Mobil 1 Oil
* Dexcool Coolant
Exhaust
* SLP Tri-Y 1 5/8" stainless steel header - Jethot coated in/out
* Stage 8 header bolts
* PFP highflow cat
* SLP 3" stainless steel cat back exhaust
* Polished Tips
Suspension/Driving Fun
* 17" ROH ZS Wheels - 8.5" front and 9.5" rear with Dunlop SP 8000 tires - 245 45R17 front and 275 40R17 rear
* 16x9.5" Vette wheels with 265 45R16 Kumho race tires
* Koni Red Hydraulic Struts and Gas Shocks
* Global West Spherical End Trailing Arms and Panhard Rod
* Centerforce Dual Friction Clutch
* Energy Suspension Polyurethane swaybar, endlink, tranny, and torque arm bushings
* Hurst Shifter
* Nardi Shift ****
* Schroth Street Legal Four Point ASM Harness
Old Nov 16, 2004 | 04:26 PM
  #26
87DJP2001's Avatar
Is he making between 250/275 RWHP to make that time with those Mods???
I think NOT.
Old Nov 18, 2004 | 08:54 AM
  #27
Zepher's Avatar
I did get my 86 Trans Am to trap 99mph, but that was with a cam, 52mm TB, headers, full 3" exhaust. Car was an LG4 that I converted to an Speed Density TPI with the 87 TPI heads and stock TPI intake, runners, and plenum.
If the 60' wasn't so bad, I probably would have hit a 13.5-13.7.
My 305 died before I could get it back to the track.
Old Nov 18, 2004 | 11:10 PM
  #28
transxtreme's Avatar
13.5 On a full interior???, I think not. 3350???? Try over 4000 with you in it, My old 305 iroc ran a 13.3 on M & H slicks, headers, big gears, no interior and a BIG shot of juice. Your gonna have to try again..
Old Nov 19, 2004 | 08:37 AM
  #29
slimdawson's Avatar
Transxtreme, our cars do NOT weigh that much.
My 91 with the 305/auto, full interior, speakers in hatch, full tank of gas and me in it weighed 3660.
Old Nov 19, 2004 | 08:46 AM
  #30
87DJP2001's Avatar
And you call yourself "Slim"..... 3660# more like "heavy".
