305 tbi to tpi or carb?
Old Apr 16, 2006 | 09:02 PM
bowtiepastya's Avatar
Ive done some research on changing from tbi to carbuerated but i didnt find out much. i am also wondering how hard it would be to switch to tpi. has anyone either changed to carbuerated or tpi. if so what do i need and how hard would this be?
Old Apr 16, 2006 | 09:36 PM
89Vert's Avatar
Re: 305 tbi to tpi or carb?
TBI to TPI is a surprizingly easy swap from what I've been told
watch for vats if you have it, or the TPI ecm you get has it,
but I'd get the TPI heads to make the swap more worth while,
electronics wise you just need the TPI engine harness,
make sure if you got a Camaro you get a harness from a Camaro
last swap my buddy did he forgot he pulled the motor from a T/A and had a bunch of problems cause battery is on oposite side
Old Apr 16, 2006 | 10:18 PM
so bare minimum i need is the intake from a TPI motor and the wiring harness. what about fuel lines, vaccuum lines, and the throttle and trans cables, is there any problem there. i am not concerned about emissions at all.
everyone i have talked to has said to drop a 350 in it. i have just recently bought this car, a '91 RS, and i have a 350 from an '82 vette but im not sure i have enough time and experience to do the engine swap. i need this car as a daily driver and i dont think i have enough time to do the swap.
Old Apr 16, 2006 | 11:22 PM
89Vert's Avatar
I wouldn't try to do any kind of swap on a daily driver, there are always "issues" that come up
Old Apr 17, 2006 | 09:36 AM
Rice Killer87's Avatar
I have done a TPI to carb swap on my old 87 IROC.
But if you cant have the car down for a while than your still in the same boat as the above posts.
Old Apr 17, 2006 | 11:42 AM
Z28SORR's Avatar
Personally, I don't think you should do this at all. Particularlly if you really think you may swap the engine down the road. Give it a good tune-up and enjoy it. Save some money while you research the 350 swap, then do it.
Old Apr 17, 2006 | 06:06 PM
thanks for all your help. ill keep doing some research before i do anything major.
Old Apr 17, 2006 | 07:08 PM
85_305's Avatar
I say you put on a MODIFIED TPI system Instead of flat-out TPI, look for an HSR or equivilent. LOTS more power/streetability that way
G-BODYT56
Jan 14, 2022 11:14 PM
Kawi
Sep 28, 2015 09:01 AM
Tarizza
Sep 20, 2015 03:26 PM
92_RS_305
Sep 8, 2015 07:47 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
