305 to 350 swap
Old Aug 9, 2005 | 04:58 PM
riphc06's Avatar
305 to 350 swap
hey guys i am swaping in a 350 for a 305 and i am extremely confused on what type of intake system i should use.....it is TBI right now....what would be the easiest to swap in? TBI TPI carb?....im clueless guys
Old Aug 9, 2005 | 05:53 PM
91-Z28-L98's Avatar
Re: 305 to 350 swap
TBI would be the easiest, considering it would involve swapping the longblock only, but its the worst way for making power. Carbed would be fairly easy as well but would probably not leave you emissions legal. You would need to get a carb specific fuel pressure regulator and I think a vaccuum advance distributor and probably a few other things I am forgetting. As for TPI, it will give you comparable power to the carburator and should give you an emissions friendly vehicle but may be quite difficult to do. You will need a new ECM and wireing harness plus a higher volume fuel pump. Some of the sensors may transfer over, but now would probably be a good time to replace them anyway. I think you will need a new throttle body and of course the TPI plenum, runners, and intake baseplate. Some have said that this is just as hard as an LT1 swap, so you might take that into consideration.
Old Aug 11, 2005 | 11:11 AM
riphc06's Avatar
Re: 305 to 350 swap
thanks for the help....i would like to go TPI but it sounds like a pain in the ***....how much power do u think i could get out of a 350 tbi? i was planning on about 300hp maybe a little more....thanks again
Old Aug 11, 2005 | 05:44 PM
91-Z28-L98's Avatar
Re: 305 to 350 swap
I'm not an authority on guessing HP potential but from my limited knowledge I would guess that 300hp from a 350 TBI was a realistic goal. Its not nearly as easy as TPI or carbed as the initake parts are not nearly as common (exhaust are the same). Also the TBI injectors sit in the way of airflow to the throttle causing more restriction. Make sure you gather a lot of info before making a descision.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
dawg irocz
Feb 10, 2015 10:33 AM
veryslowfbody
Aug 22, 2002 04:31 PM
