305 to 305 TPI
Old Oct 21, 2007 | 08:29 PM
Moshbmx1's Avatar
305 to 305 TPI
My buddy has an 86 iroc and he blew his original 305 and he is wanting to buy a 305 TPI. What all has to be done to get this to work as far as wiring and such? The PCM with the TPI motor is tuned for the a4 and he has a m5 in his car so that has to be reprogramed as well. Any good write-ups on this that anyone knows about?
Old Oct 21, 2007 | 09:49 PM
kandied91z's Avatar
the obvious is to check thirdgen.org. it should be fairly straight forward swap. depending on the options for the car most of the bugs should be ecm related. i'm sure there's more to it though as the harness will most likely be different. newer lsx motors are getting so cheap these days that unless you find a deal on a good running 350 it's almost a waste of time.
good luck with it, go to thirdgen.org if you haven't though as all the info is over there.
Old Oct 22, 2007 | 07:36 AM
Moshbmx1's Avatar
Hes a member of thirdgen so im sure hes posting over there but i thought id check over here to see if anyone had any thoughts. Thanks
G-BODYT56
Jan 14, 2022 11:14 PM
Tarizza
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
