275's on my iroc-z?
Guest
Posts: n/a
Well.. what size tires did your car come w/? An IROC has 245's I believe..
275 "SHOULD" be ok, but I am unsure. I have stock 15's, and they take 215's originally.. I am gonna put 245's on them though, I am positive that will work. If 275's fit you car, which I believe they will, they will kinda bulge out of the rim, and the patch of tire touching the ground, and give it a kool look.
I have 15 inch rims on my car with 265 tires on the back and they fit fine, I actually just got them and only drove down the street until i got a hole in my oil pan, They fit niceley though, but i never hit any big bumps yet so i don't know if they will rub when i hit a bump. My freind has 295, but he has a nice torn up spot going around his tire from rubbing.
I like 15 inch rims better than 16, but my car had 245's in the front
on a 16 inch rim and it fit fine.
the front rims i just got are 15 x 4 1/2 with 195's.
Its a little skinny but i like the look. I have a pair of 205x15 that I may try to squeeze on them.
I really want a set of traction action bars and adjustable coil overs so i could fit 295's in the rear with no problems
and maybe one day a 12bolt posi so i can get traction from both tires instead on just one.
275/??/?? 16's? What tire exactly? What aspect ratio? 245's on a stock IROC 16X8" rim is as big as I'd go. It looks normal, handles good(is safe), and price wise it's cheapest probably.
I got a buddy who put 275/50/15's on his 15X7" rims...Looks terrible, handles like ***, rubs.. LOL!
most tires have a specific sizing so figure out what you want to buy and it should tell you what the most ideal size for a 16x8 rim would be. Theres generally no need on street tires for something that wide unless youre going with a set of et streets or something.
Originally posted by dj haf
275/40/R17 16'' stock iroc-z rims
