2.8 mfi to 5.7 tpi conversion question
has anyone ever done this and if so id like to know what parts from the 2.8 can be reused and what i need to get off a tunedport car since there are 2 available in the junkyard for parting, so i can sucessfully do this.. besides computer, wiring harness ect.
Re: 2.8 mfi to 5.7 tpi conversion question
No, the V6 transmissions, both the 700R4 and the T5, have a different bellhousing bolt pattern and will not bolt up to the V8 engine. Basically you need everything from the V8 car. Radiator, front engine accessories, engine, lines, wiring harness, computer, transmission, cooler lines, tranny mount, and driveshaft. You might as well grab the front and rear sway bars and shocks and springs, too, as the V6 stuff is smaller and softer.
if i need a different trans than ill ahve to scrap the idea cause that would be too much. its really too bad iff thats the case, cause i was looking forward to having the 342 final drive gear that the v6 has on an l98 motor. anyway not that i dont believe you Kevin91Z but can anyone else confirm that the v6 700 has a different bolt patern than the v8 700.
im gonna put a mild cam into it to boost its power to that of the LO3 motor so i can hopefully get 1500 for it.
than yes ill go find me an iroc even if i have to drive to another state. i found a good page that fbody sellers post on.
how much blackrabbit
and heres the site http://www.fbody.com/
Incorrect information. The V6 T5 will bolt up to a V8. IIRC you need the bellhousing from a V8 T5 though. And you have to get a clutch for an S10. As said before, checkout thirdgen.org, lots of info on this.
I forgot about the motor mounts, yes those need to be changed, too. Basically, its not a worthwhile swap unless you're getting all the parts for free and you know how to do the swap yourself. You would spend less money selling your V6 car and buying a V8 car.
Originally Posted by Kevin91Z
Its not incorrect info, just practical info. He wants to use his V6 stuff and I said it wasnt possible. The S10 clutch you talk about is the same one as for a V6 thirdgen. And do you think a V6 clutch will be a high-performance model for a V8? I doubt it.
