2.73 Disc Posi Rear
Old Oct 5, 2003 | 07:28 PM
shwine617's Avatar
2.73 Disc Posi Rear
I am buying a 2.73 Posi disc rear from my friend for $50. I want to make it a 3.73 posi. Do I only have to change the gears? I am not sure if 3.73's will fit in the 2.73 and I am not exactly sure what I am going to need and what it's going to cost.
thanks!
Old Oct 5, 2003 | 07:48 PM
Rice Killer87's Avatar
ull prob. have to change the carrier too. the gears will prob. cost around $300 i think and ull prob. need an installation kit that comes w/ new seals,spacers and such for the new gear installation
Old Oct 5, 2003 | 09:12 PM
Geezer powered's Avatar
whats wrong w/ your rear now?
Old Oct 5, 2003 | 10:40 PM
IROC350's Avatar
if its a 9 bolt rear, you'll have to change to a 3 series carrier for about 600 bucks new and then 300 for gears. 2.77's came in the 9 bolt, and since you have 2.73's you have a 10 bolt. stuff will be cheaper!
Old Oct 6, 2003 | 04:34 AM
Zepher's Avatar
You'll need gears for a 2 series, an shim kit, posi additive, gear oil, I'd change the bearings and axle seals as well.
If you have drums, you'll need a prop valve from a disc car.
It will run you about $450-600 depending on labor price.
We get our gears done for $150.
Gears, $150
Shim Kit, $30 or so
Solid Pinion Spacer, $20, this is highly recommended over a crush collar.
bearings and seals, about $80 or so
Gear oil, $15
Posi Additive $6
Don't know what a prob valve costs, probably $40 or so.
HarleyZ28
Oct 5, 2015 06:23 AM
R@mpage
Apr 20, 2015 10:02 AM
ddr698
Jan 9, 2015 10:05 AM
DropTop91
22
Aug 8, 2002 10:53 AM
